Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 07-20-2004, 01:28 AM   #1
Max-97CivicEx
Fuel gauge not reseting after fill up
Ok, this is the second time this has happened - I go to fill up and the fuel gauge does not seem to detect the fill up. The first time was about a month or two back and opening and re-closing the gas cap seemed fixed it. It happened again today and this time nothing I do seems to reset it. What is even wierder is that the fuel gauge continues to go down as I drive,as if I did not fill up at all. Another wierdness factor is that it happened at the same gas station, which I do not usually use. Any thoughts?
Thanks
-M
[EDIT] Oh, yeah, the car is '96 328i
Max-97CivicEx is offline   Reply With Quote
Old 07-20-2004, 02:44 PM   #2
Max-97CivicEx
Well, after searching the net I found a solution, although I am still curious as to why this happened
The solution is:
With key in off position remove fuse 31
Turn key to II position
Turn key to off position
Replace fuse 31
This seems to reset the fuel sensor.
-M
