Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-19-2004, 08:27 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Electric Turbo
I've seen this on Ebay a couple times... It's a electric turbo. It goes on the intake, but instead of being ran from the exhaust, its hooked up to the battery with a button inside the car to activate it. Does this really work at all? It seems to me that there should be some increase, but nothing like a real turbo. Im not looking for massive h.p. increase, but I would like more. Would this work?
Old 07-20-2004, 03:36 AM
Wolf's Avatar
Wolf Wolf is offline
Send a message via AIM to Wolf
Re: Electric Turbo
http://www.automotiveforums.com/vbul...d.php?t=242617
Old 07-20-2004, 02:23 PM
Reed Reed is offline
Send a message via AIM to Reed
Re: Electric Turbo
if its not driven by exhaust then its jsut a supercharger.
it might get you slightly above ambient and low rpm but you probobly wont see much at higher rpm.
Old 07-20-2004, 03:13 PM
SaabJohan SaabJohan is offline
Re: Electric Turbo
I think those have been tested on a dyno, I believe the result was a small powerloss due to the restriction in the intake they cause. Many of them are just electric driven fans, which aren't suitable for the purpose at all.
Turbochargers use a carefully designed compressor and a turbine which even for small low boost engines can deliver a power which is several times the power output from the electric motors of those little things which is needed if you want to get any boost.
You can find real turbochargers from a couple hundred us dollars and up, buy the real thing instead.
Old 07-21-2004, 02:48 PM
longlivetheZ's Avatar
longlivetheZ longlivetheZ is offline
Send a message via AIM to longlivetheZ Send a message via MSN to longlivetheZ
Re: Electric Turbo
I read an artical about a electric supercharger that's been developed recently that is actually powerful enough to be useful, but only for a short time...think nitrous. The guy's been working on it for...like...15 yrs or something because he's been waiting for electric motor technology to become good enough for what he wants to do. The ones he found to be powerful enough were way too big. I think what he ended up doing was using 3 smaller electric motors. He had the setup on his VW Bug for a while and said it worked.
Most of them out there are far too weak to do any good and I wouldn't be surprised if they actually did cause a HP loss.
I'll see if I can find the article I read about the good electric supercharger. You guys would probably find it interesting. I thought I saved it in my favorites, but I didn't.
Who cares what's in your wallet...what's in your garage?
VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31
Hope you can see the tiny pic...AF reduced the size limit!
Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Old 07-24-2004, 12:04 PM
david-b's Avatar
Dave is THAT guy
Re: Electric Turbo
Ahhh.
So basically, I should just buy a real turbo system or super charger for my Talon? That these are just hoaxes? Oh well Thanks
Old 07-24-2004, 03:16 PM
Re: Electric Turbo
Most of them are b.s., yes. A turbo is the most efficient, effective power adder that you could put on your car...you're better off going that route than anything else, anyway.
Old 07-25-2004, 03:19 PM
Re: Electric Turbo
if you are getting it for a talon why not go with a turbo 4g63 its been proven since like 1988 you can get a block for like $200 and a built head for like $300 more or less or just get the whole motor with turbo and accessories and just get it all on ebay
Old 07-28-2004, 03:02 PM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: Electric Turbo
this is the only one ive ever even thought about being worth it. They have dyno sheets, and a money back guarantee. They claim 800CFM at 2 PSI. And its a turbo design with 50 some blades. I was gonna buy a nice new supercharger for my car, but i got rear ended and all themoney i saved this summer went to fixing it, so im thinking about getting this one. . .
https://cargodzcc.hivelocity.net/cgi...egory_Code=pi1
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 07-29-2004, 02:45 PM
david-b's Avatar
Dave is THAT guy
Re: Electric Turbo
If I could afford a new motor, I would get one with a turbo. However, lacking a lot of $$$$. I'm just doing "bolt-ons" right now. I guess I'll stick with that for this car. No major rebuilds. Should've just bought a TSi...
Old 07-29-2004, 04:02 PM
public's Avatar
public public is offline
Re: Electric Turbo
A roots blower will give the most bang for the buck. Way more than a turbo of the same size. The differences is cost and availability. Did you ever see a top fuel dragster with a turbo. Turbos were orginally concieved for diesel engines that do NOT operate over a wide RPM band. They gained popularity in cars back in the 1980's only because they made less noise than a supercharger/blower for the same boost.
Old 07-29-2004, 10:08 PM
-Jayson-'s Avatar
Re: Electric Turbo
forgive my noobieness, but whats a rooots blower?
2009 Ninja 650 R
stock for now...
Old 07-30-2004, 11:59 AM
pro_am pro_am is offline
Send a message via MSN to pro_am Send a message via Yahoo to pro_am
Re: Electric Turbo
A roots blower is one that bolts on the the heads, like an intake, and you put your Two carbuerators on top of the blower. I think there may be an "intake" on the bottom of the blower to adapt it to the heads, but i'm not sure. The blower is belt driven.
Jake
Old 07-30-2004, 01:45 PM
Re: Re: Electric Turbo
A roots blower is one of the worst means of forced induction. The bulky roots compressor consumes a lot of power from the crankshaft and gives a high intake air temperature.
Top Fuels don't have turbochargers since they aren't allowed (as in most of the fastest drag racing classes), if the were we would see a powergain of about 1000 hp for a turbocharged Top Fuel.
How the roots works
Today lysholm screw type superchargers are often used instead of the roots which offers a better efficiency but at a higher price. The screws aren't allowed in top fuel either, they are however allowed in at least one of the faster drag racing classes but then they must be used together with a smaller displacement.
Old 07-30-2004, 02:15 PM
Re: Electric Turbo
yeah a roots blower is less than 70% effecient whereas a turbo can be upwards of 90%. if you really want a supercharger then go with a centrifugal one. it has a compressor just like a turbos but obviously with different blade angles, sizes, and numbers. they are far more effecient that a roots blower.
Closed Thread
