Old 07-19-2004, 07:43 PM
Shalin's Avatar
Shalin Shalin is offline
Unhappy I got orange peel problems, PLEASE help!!!
Hello, im new to the car modeling thing, and this is my first model,
I just finished painting my AMT 1970 Chevelle SS 454 with Testor's "Gloss Bright Blue" and ive got an orange peel problem. I have read the FAQ, but i still need details on how to remove orange peel before the rubbing compound and wax. Due to the area i live in, the highest grit sandpaper i could obtain was 1500, and my parents wont let me order higher grits from online. Also, my stupid sister sprayed the rest of my can of bright blue into the gutter for "FUN" so i dont have anymore blue paint,and i dont wanna go out and buy a whole new can if i mess up!
Sorry for the long post
Any help would be appreciated!!!!
Thanks,
Shalin
Old 07-19-2004, 07:45 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: I got orange peel problems, PLEASE help!!!
1500 seems good enough? Just be careful, and dont over sand.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 07-19-2004, 08:13 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
use lots of water when sanding, and since you dont have any more paint, dont sand near any edges!
Old 07-20-2004, 12:39 AM
VTEC-DA9's Avatar
VTEC-DA9 VTEC-DA9 is offline
Send a message via AIM to VTEC-DA9
Have you cleared it yet? If you did, even better, as you won't run the risk of sanding through the colored base coat to smooth out the orange peel. Just like the guys said use plenty of water and make sure you are very careful around the edges, ie near door jams, hood jams etc as the paint tends to be a lot thinner there and sanding right throug it is very common. If you haven't cleared it yet, then I would suggest you do so, let it dry then start the task of color sanding it.
Tri
tlmai009ATyahooDOTcom
Old 07-20-2004, 01:05 AM
PRIVATEER's Avatar
PRIVATEER PRIVATEER is offline
Send a message via AIM to PRIVATEER
I like to add a little dishwashing soap to the water when I sand. Your gettin' good advice so far.
Old 07-20-2004, 01:11 AM
Shalin's Avatar
Thanx for all the help guys, im gonna sand the car tomorrow and see how it goes, wish me luck!!!!!
Thanks,
Shalin
