Old 07-19-2004, 06:09 PM
Sachse Sachse is offline
93 mustang ac problems
My car runs fine without the air conditioning on. When you turn it on however, it doesnt want to idle. It just dies. If I keep the gas going, it wont die also. What can do I to fix this problem or what should be replaced?
Old 07-19-2004, 07:18 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: 93 mustang ac problems
Sounds like the compressor is locking up when it engages. Does the belt squeel or anything before it shuts off? Or does it shut off instantly, as soon as you flip the switch to on?
Old 07-19-2004, 07:30 PM
If the ac is on and the car is sitting there it will surge some below the normal idle and then die. If I keep my foot slightly on the gas it keeps running.
Old 07-19-2004, 08:17 PM
351wStang's Avatar
Well then it sounds like your A/C is causeing a strain on your engine. Probably due to a worn out stock compressor. But, does your A/C blow cold when the car is trying to die? Does it blow cold at all? I'm no A/C expert but I'd say you need to replace your compressor and probably have to replace your dryer too if you want a warranty (which you always want when working with A/C).
Old 07-19-2004, 09:14 PM
the compressor is good, the ac blows cold when I am driving and give the engine no problem
Old 07-19-2004, 11:12 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
It's not the compressor. Your compressor is causing strain on the engine's electrical system for some reason. What are the volts at when the AC is on comparied to off? Are you running underdrive pulleys?
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
