Old 07-19-2004, 04:51 PM
MasterBraetec's Avatar
MasterBraetec MasterBraetec is offline
Send a message via AIM to MasterBraetec
Eclipse engine 420A or 4G63
what is the easiest way to tell the two of them apart?
I was told the 95 gs could have either one of the 2
Old 07-19-2004, 05:00 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Eclipse engine 420A or 4G63
No. The 420a is in gs/rs. The 4g63 is in the turbo cars GST/GSX
For Sale 98 Eclipse GS, 5 spd
Old 07-19-2004, 11:15 PM
gstclips gstclips is offline
Send a message via AIM to gstclips
who told u that?....
THE OFFICIAL AF PIMP! - love EclipseRST[Banned]
1997 Gs-t Eclipse
6 bolt + other toys
Currently 295whp
Old 07-20-2004, 01:27 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
The 420A sits at about slightly top left-ish, if your looking at your car with the hood open. The 4G63 should have mitsubishi and 2000 on the valve cover and is located near the center...as i see it. Oh and yeah, the 4G63 will blow the pants off the NT 420A so that helps to0 (unless your RS-T, hehehe)
The daily driver. The weekend cruiser. The lazy shop hog.
Old 07-20-2004, 11:57 AM
xllSkylinellx's Avatar
xllSkylinellx xllSkylinellx is offline
Send a message via AIM to xllSkylinellx
Has anyone or know anyone that has swapped a Mitsu Evo motor into their Eclipse? Can it be done? How much does the evo motor go for, I know it's for awd car, can it be swaped in to a fwd car?
Why does the Evo and GST/X motor have the same engine code? Where does the power difference come from, if it's the same motor?
97 Accord - Stolen
99 Eclipse - commute car for now
DSM bible
Click here for some real skilled driving - JDM video yO
Old 07-20-2004, 03:47 PM
firesdoom's Avatar
firesdoom firesdoom is offline
Send a message via AIM to firesdoom Send a message via Yahoo to firesdoom
Re: Re: Eclipse engine 420A or 4G63
I have a 92 GS with a 4g63. I guess 1g's don't have the 420a. The engine type should be on the firewall somewhere.
Old 07-20-2004, 04:20 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
look for the sidemount on the passenger side
-Agim
Old 07-20-2004, 05:06 PM
2of9 2of9 is offline
- Evo 8 Motor...possible with money
- Evo 8 motors go up for at least $3000, and again its possible to go FWD with the money, but why would u waste money on building one?
- Same engine code?....hmmm becuase both are used as 4G63 eninges
- Power Difference comes from the 'bigger' turbo and turbines in the Evo 8. The Evo 8 i also heard, they did something with the engine so crankwalk wouldnt occur as much.
well...this is the best i could do...
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 07-20-2004, 05:16 PM
ashah000's Avatar
Re: Re: Re: Eclipse engine 420A or 4G63
Yes 1g's dont have 420a's
Old 07-20-2004, 05:42 PM
Raz_Kaz Raz_Kaz is offline
The 420A motor comes in all 2nd gen N/A cars. I do believe any 4g63 motor can bolt up to the DSM's it just depends on the drivetran layout that you can run into issues
I can check later when I get home
Old 07-20-2004, 09:01 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
just look under the hood or against your firewall.....it should tell you what the motor, tranny, etc. is....or the intake pipe should be on the left side....
Old 07-24-2004, 07:04 AM
slowgsowner slowgsowner is offline
u have the 420a all 2gen gs rs came this way.
Old 07-24-2004, 05:18 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
420A ----\/
4g63 ---\/
simple enough
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 07-25-2004, 01:57 AM
yep,thats what mine looks like thnx
Old 07-25-2004, 07:09 AM
kjewer1 kjewer1 is offline
AF - Advisor
Its a matter of which side the motor is on, and more importantly which way it rotates. The 420A is back asswards, as is the EVO4 and up. If the motor spins the wrong way, you cant just flip it around and run it. The piston pin offset will be on the wrong side of the rod, etc. The motor mounts are also all wrong.
And FWIW, there isnt enough difference between the regular 4g63 in the us cars and the evo 1/2/3 to make it worth the swap. Its the same damn block. But sometimes in purchasing one of those motors or one from a galant you get a 16g and 510 injectors out of the deal. But those are arent very good reasons.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
