Old 07-19-2004, 03:21 PM
actionpat actionpat is offline
possible fuel injection problem
I replaced the hood struts three days ago. Two days ago i went to start the car and it wouldn't start. The engine cranks, has spark,fuel pressure, and was running perfectly fine before this. When i spray starting fluid into the intake, it catches but there is not enough fuel for it turn over. It is possible that the injectors are not getting any voltage. Does anybody have any ideas?
Old 07-21-2004, 11:16 PM
Froze_Tread Froze_Tread is offline
Send a message via MSN to Froze_Tread
Get your hands on a noid light and check to see if their firing. If i remember right these things have to crack at a certian speed in order for the computer to fire the injectors being that it doesnt whant to flood the engine when i knows it wont start. With that said check your battery connections and its condition usually a jumper box will start those cars though. And your sure that you have enough fuel pressure, not doubting u at all here just curiouse. make sure the fuel pump is running by listening to it. easy place to do that from is by removing the fuel cap and listening through thier.
Old 07-23-2004, 11:35 AM
replaced the fuel pump. Now have spec. pressure to the fuel rail. Again, good spark and engine cranking. Don't hear the fuel injectors pulsing though
Old 07-23-2004, 09:35 PM
Re: possible fuel injection problem
You might not be able to hear if no noid light u might be able to use a screwdriver a long one usually to use as a stethascope to listen to them. Are you sure the car is cranking over fast enough? as in enough battery voltage and that the starter is sound? Good luck.
If Fords didnt break all the Time i would be out of a job and a few million other Ford mechanics. Just like the Firestone incendent.
Old 07-24-2004, 02:26 PM
Checked fuel injectors with a light and the screwdriver/stethoscope. hard to tell but the injectors are getting electricity. battery has 14 volts and starter is turning the engine. if i spray enough ether into the intake the engine starts to catch but does nto have enough fuel to run.
Old 07-24-2004, 07:32 PM
how did u check fuel pressure and did u replace the fuel filter?
Old 07-25-2004, 12:44 AM
i checked the fuel pressure with a pressure gauge at the shcrader valve. yes i replaced the fuel filter.
Old 07-25-2004, 12:46 AM
thanks to Froze Tread for all your help
Old 07-25-2004, 01:25 AM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
Did you get it fixed?
From reading the thread, I take it that you can hear the fuel pump run, and that fuel pressure is indeed normal.
If ALL the injectors aren't firing, I'd take a close look at the wiring harness, and see which wire is the ground wire. (The wire color that is common to all fuel injectors) Inspect for a disconnected or loose harness, and track that ground wire down to where it attaches to ground. You may have a bad ground.
