Old 07-19-2004, 02:32 PM
possessedcricket's Avatar
possessedcricket possessedcricket is offline
Billet Grill
What is the difference between bolt over and direct replacement, and what are the pro's and con's?
Thanks
Old 07-19-2004, 03:10 PM
simple_country_guy's Avatar
simple_country_guy simple_country_guy is offline
Send a message via Yahoo to simple_country_guy
Re: Billet Grill
A bolt over over grille is just that... it is a very easy install. Simply place the new grille over the exixting one and tighten the bolts. PRO's- very easy fast install. CON's- you will see the factory grille behind the new grille. The replacement grille is just that as well.. you remove the factory grille, pop out the factory mesh insert, drill mounting holes and bolt the new grille in. PRO's- much more custom look. CON's- will take alittle more time and if you are not very mechanically inclined it may be difficult.
Sure, I know how to do that......
Old 07-19-2004, 04:12 PM
Re: Re: Billet Grill
Sounds good, thanks for the input.
I ordered a bolt on but switched to a replacement at the last minute. Hope that was a wise choice for $70 bucks
Old 07-19-2004, 06:37 PM
Re: Billet Grill
I think you will be much happier with the replacement.
Old 07-20-2004, 02:54 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
I agree.
*Under Construction - New sig to debut*
Old 07-20-2004, 03:08 PM
lovemytruck lovemytruck is offline
Send a message via AIM to lovemytruck
Re: Billet Grill
they are only 70 bucks? i priced one a while back at the local truck store they told me 160 for my 02 silverado? where did you get yours?
Thanks
chris
