Old 07-19-2004, 02:25 PM
Takumi8187's Avatar
Takumi8187 Takumi8187 is offline
Amp Question
Hi, I have a JBL 180.2 amp, here's the manual:
http://manuals.harman.com/JBL/CAR/Ow...nual/bp_om.pdf
Will 12 gauge speaker wire work on this amp?
Old 07-19-2004, 04:42 PM
mjshort18 mjshort18 is offline
Re: Amp Question
not sure for that specific amp but the bigger the better in this case. it can never be too big. i would suggest at least 8 gauge.
Old 07-19-2004, 05:06 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Re: Amp Question
8 gauge? for 180 watts? bigger isn't always better. With bigger wire, restinace goes up. Yes, that size wire is fine for speakers, but not for power and ground
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 07-19-2004, 05:21 PM
Takumi8187's Avatar
Re: Amp Question
OK, thanks. One more thing, how many watt amp install kit should I get for that amp?
Old 07-20-2004, 05:51 AM
smartjay28 smartjay28 is offline
Send a message via AIM to smartjay28
if you got them money and plan to get a higher wattage amp, get a 4 guage. if not you can stick w/ 8 gauge.
http://www.acura-legend.com
Old 07-20-2004, 01:08 PM
Re: Re: Amp Question
i thought that wire is like a pipe with water going through it. if you have a small pipe then you will only be able to get a small amout of the water through. with a bigger pipe you will be able to get a whole lot more through. maybe i am just wrong though. when does resistance come in to play?
Old 07-21-2004, 06:45 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
Re: Amp Question
this site rocks.....
http://www.bcae1.com/
click on #16 (wire) on the right hand side and use the wire calculator.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
