Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-19-2004, 09:38 AM
SlowerCivic SlowerCivic is offline
auto to manual conversion?
Ok im going to do an engine swap b18c1 into a 95 civic and i want to do that auto to manual conversion for it also,heres a list of the things I think ill need to do the auto to manual conversion that wont come with the swap.Will I have to get these things from an integra or will any application work?Heres where im getting the motor from
http://www.hmotorsonline.com/shop/sc...age&item=30009
Shift linkage
Intermediate shaft for manual tranny
Clutch master cylinder
Clutch reservoir
Clutch slave cylinder
Hydro clutch lines
157 second quarter mile.
10 min. 0-60
2.7 sec 60-0
79 mpg
Old 07-19-2004, 03:11 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: auto to manual conversion?
Thats pretty much it.
Old 07-20-2004, 12:25 AM
RPMtuner RPMtuner is offline
throttle cable accelorater brake and clutch pedal assembly. ecu and axels but thoes will probably come with the motor you will need to wire up for nutural safty and your reverse lights and you will need to remove the automatic ignition lock silinoide
depending on your application you will need to modify the passenger side mount bracekt
Old 07-20-2004, 01:46 AM
mellowboy's Avatar
Yeh most of it comes with the motor. Well it should. Yeh you will need the clutch pedal. Just so you know i would change the brake pedal also. Its really close to the clutch pedal. Ecu should come with the motor also.
