Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 07-19-2004, 08:52 AM
ERINCROOK ERINCROOK is offline
98 trooper transmission trouble
I Have A 98 Trooper With 84000 Miles. It Sound Like The Automatic Transmission Is Going To Fall Out When It Changes From 2nd To 3rd. Turn The Engine Off And Restart And The Transmission Changes Great. It Has Done This About 4 Times In The Past Month. Any Suggestions
Old 07-21-2004, 12:54 AM
RexNfx400's Avatar
RexNfx400 RexNfx400 is offline
Re: 98 trooper transmission trouble
"Harsh shifts" or "limp-mode"
Someone needs to check for codes and monitor computer data stream to see whats up. Probably an electrical problem.
Old 08-12-2004, 08:42 AM
paulnewman paulnewman is offline
Hi
Did you resolve this yet. I've just bought a 99 trooper with the same symptoms. Would like to know how to sort it.
Old 08-12-2004, 07:57 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
be sure the trans fluid level is right needs to be checked while hot ideling in neutral
Old 08-16-2004, 09:00 AM
I think my wife has figured this out - believe it or not !!!
The fault for us has not occured since allowing sufficient time for all sensors and management systems an opportunity to settle on idle before putting it into gear.
Im not sexist just amazed at her intuition on this one.
Anyway it works for us - if anyone knows why it would be interesting to know, and if the original submitter has the same result.
Old 08-16-2004, 06:44 PM
still sounds like your low on fluid I would have it checked
