Old 07-19-2004, 08:10 AM
gravityhotspot gravityhotspot is offline
Secondary Air injection system
I have a 2000 Taurus with the check engine light on. The error code is 1413 Secondary Air Injection System Monitor Circuit Low Voltage. I'm a pretty good parts changer but not much of a mechanic. What do I replace or clean to corect this fault?
Thanks in advance,
Rob
Old 07-19-2004, 01:30 PM
Willyum Willyum is offline
Re: Secondary Air injection system
Rob, If you haven't already done so you might take a look on www.batauto.com for info about fault codes. Also there are a thousand or so technicians who visit the site and likely will give you specific info about the problem.
Old 07-22-2004, 09:23 PM
Car Pal Car Pal is offline
check the maxi fuse in the engine compartment fuse box.
if it is blown you could have water in the saim
