Go Back   Automotive Forums Car Chat > Warehoused Archives > Introductions
Introductions Welcome to AutomotiveForums.com. Introduce yourself here so we can get to know you better.
  Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-19-2004, 03:19 AM
Vince@Daytona Bch. Vince@Daytona Bch. is offline
Question Cure for Sugar in Gas Tank..?????
Water & Sugar in Gas tank that contained approx.
4 gals. of fuel.
Any 'qualified' idea's on a 'solution' other than replacing
the tank?
Perhaps there are some 'shortcuts' that I don't know
about.
Awaiting Your Replies.....
Vince...
Old 07-19-2004, 03:24 AM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
Re: Cure for Sugar in Gas Tank..?????
Dissconnect the fuel lines that go to the engine, turn the fuel pump on until gas is fully emptied out of the tank. I'm not sure if this will work tough, sounds logical
Old 07-19-2004, 03:34 AM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
Sugar does not dissolve in gasoline, meaning that it is possible to drop the tank, drain it out, clean it as best you can, replace the fuel filter and hope that none got past it into the delivery system. Normally if it were just water I would recommend a gasoline additive to remedy the problem, but since you will have to drop the gas tank anyways, you can take that opportunity to clean the tank of any contaminants.
Assuming none of the sugar got past the filter, the main issue is the fact that your fuel filter is clogged. You will have to clean out your gas tank or else every new filter you put in will become clogged very quickly.
Beer tastes better upside down.
Old 07-19-2004, 11:41 AM
nex1's Avatar
nex1 nex1 is offline
Send a message via ICQ to nex1 Send a message via AIM to nex1 Send a message via MSN to nex1
shoot the ex girl/boy friend hehehehee
Old 07-19-2004, 12:17 PM
Thanks for the response/s.
Can't shoot the guy yet. He's behind bars now.!
The 'sugar/water' was discovered prior to starting
engine and engine 'has not and will not be started' until this problem is corrected.
integra..Mechanical fuel pump is mounted on engine, so am not able to 'pump out' as suggested.
Removal of tank itself looks like 'a big job' on this
'86 Z28 and I was hoping to find a sure-fire way
to correct this problem without removing the tank.
I appreciate the input.
I'm a 'newbie' on this MB and was hoping to Post this in the Camaro section but it looks like I'm
posted in the introduction section instead.
Any more ideas?
Vince
Old 07-19-2004, 01:44 PM
integra818's Avatar
Re: Re: Cure for Sugar in Gas Tank..?????
Originally Posted by Vince@Daytona Bch.
Any more ideas?
Sell the car.
Old 07-19-2004, 03:39 PM
Raz_Kaz Raz_Kaz is offline
Howdy, keep questions like thes in the correct forum
thanks
Old 07-19-2004, 05:33 PM
I've Posted in the correct Forum now.[camaro]
Thanks 'all' for responding.....
Sorry about the Forum mix-up....
Vince
