Old 07-18-2004, 09:26 PM
wiu_2002 wiu_2002 is offline
tranny swap question
can a 4g63t be mounted up to a 1.8 transmission? I have a 90 laser rs turbo and i want to drop it in a 92 eclipse.
Old 07-19-2004, 06:13 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: tranny swap question
if the tranny is a 5speed it should work auto it wont
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 07-20-2004, 04:07 PM
it is a 5 speed. but would i lose torque?
Old 07-20-2004, 04:29 PM
dupeto_e's Avatar
dupeto_e dupeto_e is offline
i dont see how does a tranny from 1.8l is goin to fit 4g63 engine. from what i see F5M22 tranny is used in the 1.8l and 4g63 N/T , and FM533 for the turbo models. but than , if the FM522 mounts to a 4g63 N/T than, y wouldn't it fit a turbo model. i dont know, probably i'm wrong but u need to do some research. also i'm sure that the gear ratios are different, so find out how would this affect the whole thing. the 1.8l tranny might not be strong enough. just my 0.02$
p.s. here some specs...
http://64.233.161.104/search?q=cache...1g+1.8+l&hl=en
[IMG][/IMG]
Old 09-12-2004, 10:09 PM
macder macder is offline
Send a message via MSN to macder
I have a 1993 talon ES w/ 4g63NT motor and have succesfully installed a 5 speed transmission from a 4g67(1.8), works fine, just the rpm's are higher in 5th on the highway, other than that, dont see any difference
