Old 07-18-2004, 03:13 PM
91CamaroMan 91CamaroMan is offline
Question 91 Camaro V6. 5spd. Ignition Problems
For the past 7 months (january-July) my 91 Camaro's starting has been acting up. At first I thought it was the starter, after having the starter fixed it didn't have a problem for about 3 weeks then it starting having the same problem. The Problem: When the key is turned the starter makes a click (just once per turn) but doesn't start.
What I've done: 1)replaced the starter, 2) tested the battery, 3)changed keys.
When I changed keys I didn't have any problems with starting the vehicle for about 2 weeks.
I'm just about fed up with the problem.....can anyone give some advice on what I should look at or get done with my car? Would this put a big dent in someone's pocket book?
Old 07-18-2004, 03:28 PM
coindex's Avatar
coindex coindex is offline
Send a message via ICQ to coindex Send a message via MSN to coindex Send a message via Yahoo to coindex
Re: 91 Camaro V6. 5spd. Ignition Problems
Have you checked your battery output and your alternator output? Is the charging system working properly?? If not you more likely need an alternator. If this is ok, check your connections to your battery and starter relay. Are they tight? Might be a loose connection there which is not transmitting the power you need.
In my opinion, I think its your charging system (alternator output). Have an amp load test done on your battery to
Old 07-18-2004, 03:48 PM
Thanks..I'll check it today.
Old 07-18-2004, 04:22 PM
I just got the Output checked for the Alternator and Battery. Both came out good. I got it checked at an Advanced Auto Parts store and the manager told me about how he had to replace his ignition switch and how much of a pain it was. Do you think that it could be the switch. The key does have chip on it. The problem happens randomly and I never know when it will happen. I've had it happen to me in the morning and in the middle of the day after starting it many times without a problem. Any other suggestions? thanks.
Old 07-18-2004, 04:25 PM
Also...some days I don't have any problems. Usually when the problem happens I turn the key off and put it back in or I'll jiggle the key in the ignition...half the time that works right away and the other half it takes a few more trys.
Old 07-18-2004, 07:05 PM
coindex's Avatar
that's a good possibility, ignition switch could be faulty. Try some tests on the ignition circuit in your steering column see what you find there.
Hopefully that helps and you find the problem.
Old 07-18-2004, 07:38 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
could be ignition switch, could be VATS, before they break, sometimes the wires just wear though, and cause an inttermittant starting problem.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-19-2004, 10:52 AM
A friend told me to try some kind of ignition cleaner. Should I try that before checking out the wires in the ignition?
Old 07-19-2004, 06:02 PM
89IROC&RS's Avatar
wouldnt hurt nuthin
