Old 07-18-2004, 02:34 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
aaarrggggg!!!!!
hey guys, got a question. i took apart the distributor in both camaros a while back, to get the ICMs out. and when i did, i left the air filter off the RS while i got the right ICM for the IROC. (slams head into wall), well, i got the IROC put back together, and shes running great. but i lost a screw to put the RS back together, so she sat a bit longer. well, today i put her back together and tried to fire her up, she cranked and cranked and cranked, and fired, ran and died. so i took off the air cleaner, and started her up again, and held her at 1500rpms, the engine was shaking side to side, misfiring, and when i let her idle, she would stall and fuel would spray up out of the throttle body. she was running perfect before i did this.
two things to concider are that while she was sitting she was apparently attaked by mud daubers, cuz every bolt hole on there is packed and sealed. so im thinking maybe one got into the engine and did something???
two, on the ICM harness the red connector is gone, and the wires are free floating so i put them on the way they seemed to want to go, and put it back together. but there is a chance i put them on backwards, but i would have thought it wouldnt run at all if i did that. but it seems like its almost running 180 out. coudl that have caused it you think?
shes running pig rich, i can smell it, ive got so much to get done today, i really thought this was gonna be a ten minute project, dont have time for this all i did was take off the air cleaner, undo the distributor cap, lean it forward, and R&R the ICM in the distributor, then put it all back together. damn the past few days have been shitty. anyway, any insight on this would be great.
-erik
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-18-2004, 02:48 PM
coindex's Avatar
coindex coindex is offline
Send a message via ICQ to coindex Send a message via MSN to coindex Send a message via Yahoo to coindex
Re: aaarrggggg!!!!!
did you pull the distributor? If so, you probably installed it to retarded, and you have to repull it and advance it. Sounds like your engine isn't advanced enough that would be my guess, though the connector thing may be a problem to but don't they only connect one way?
Old 07-18-2004, 03:03 PM
89IROC&RS's Avatar
Re: aaarrggggg!!!!!
fixed it. but no i didnt pull the distributor, although it was pretty much running 180 degrees out anyway.
it was the wires to the ICM from the distributor. i had them backwards cuz the connecter was long gone, they were electrical taped on there when i pulled em. so when i wired em backwards the distributor signal to the ICM was backwards, fixed em, and shes runnin like a champ again
Old 07-18-2004, 03:23 PM
Pewter'01SS's Avatar
Pewter'01SS Pewter'01SS is offline
You found your screw up in a half hour??? Damn, when I do something I wasn't suppose to, it's usually days under a hood shouting "WHAT THE F***!?! "
Old 07-18-2004, 04:26 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Re: aaarrggggg!!!!!
not as bad as the time I put the spark plug wires on all back asswards. you can do something 100 times and still fuck it up on 101
Old 07-18-2004, 07:29 PM
89IROC&RS's Avatar
Re: aaarrggggg!!!!!
29 minutes
Old 07-18-2004, 07:38 PM
lol, now you're just bragging.
