Old 07-18-2004, 12:31 PM
bigmann245 bigmann245 is offline
can you believe this
the wire i fixed on the starter now when the car is running the wire glows red hot and starts to smoke and burn. i dont know exactly what wire it is. all i know is when i hooked it back up, the fuel pump primed (which is the problem i had before, it wouldnt) and the engine started fine. but now it glows red hot and if i keep it that way it will just melt and break again. any suguestions on where and what the wire is? it connects on the right side (as your looking at the engine from the front) and the block it connects to is round and has a bunch of wires connected to it. i keep saying starter but it might be a relay or something like that. let me know. thanks.
Old 07-18-2004, 01:30 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: can you believe this
pictures may help if your not sure what your dealing with.
Old 07-18-2004, 01:33 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Did u replace the entire wire? If so or even if you didnt, I think you may need a new and larger gauge wire. I'd be willing to bet that(if you did use the old wire over) it's corroded as hell inside the covering. My suggestion: Get some new wire from the hardware store, perhaps a larger gauge, and then see what happens!
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-18-2004, 01:56 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
From what you described, it sounds like a wire off the power distribution block on the drivers side inner fender. There are a bunch of wires off there, do you know where it goes to? A picture would also be great.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-18-2004, 02:39 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
i think he's referring to the starter relay... i can't think of why it would constantly carry current tho...
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 07-18-2004, 06:13 PM
how do you add pictures?
Old 07-18-2004, 06:38 PM
http://files.automotiveforums.com/ga...&ppuser=205023
that is the link where the pictures of the wire that is glowing can be seen. please let me know what you think.
Old 07-18-2004, 08:04 PM
HiFlow5 0's Avatar
Stanger
Not sure where that one wire goes to. Trace it and find what's on the other end of it. It could be just as simple as replacing the wire with a newer, thicker gauge wire.
-2013 Ford Flex
-1999 Ford F150
Old 07-18-2004, 10:43 PM
Re: Re: can you believe this
the wire says "fuseable link" on the side. what is that?
Old 07-19-2004, 01:04 AM
Re: Re: Re: can you believe this
that's a wire that's designed to fry itself if the current going through it is too high for the circuit it protects. it must be replaced with another fusible link of the same guage.
-Andy
