Old 07-18-2004, 12:20 PM
joesuburban joesuburban is offline
99 front passenger carpet wet
The front passenger carpet is always wet. I first thought the water was coming in from the outside, but it is raining today, and the water is not getting worse. I am thinking it is the a/c drain in the passenger compartment. Does that sould correct? If it is, does anyone know how to clean it out? thanks. JC
Old 07-19-2004, 07:16 PM
Pamsdad Pamsdad is offline
Your A/C drain may be clogged.
Should be located on firewall...
97 Chevrolet CC Dually
00 Blazer
Old 07-20-2004, 04:05 PM
Old Dave Old Dave is offline
Smile Re: 99 front passenger carpet wet
Pamsdad is correct in that the drain is probably clogged. Raise the hood when the engine is cool and locate the two metal lines that go into the evaporator throught the firewall. There will be a rubber elbow about 1/2" in diameter that turns down toward the frame. Carefully pull this off and take a stick or a plastic straw and poke back in there and see what comes out. I just did this last week on my 97 Suburban and it had a spider nest in there. It's not easy to get the elbow back on since it's between the two metal lines, especially when you have hands the size of mine. Good luck...
Old 07-21-2004, 09:59 AM
chaddyp chaddyp is offline
If there is a sweet/stale smell the wetness could also be from the heater core. Has the Radiator coolant been low? I suggest looking into that.
Old 11-28-2004, 05:13 PM
99suburban2wd1500 99suburban2wd1500 is offline
wet carpet - water leak - a/c drain
I have the wet carpet problem too in the front passenger side of my 99 suburban.
I think I've located the metal lines per "old dave", but they look like supply and return for the heater coil, not freon lines
and the drain connection is not between them it's next to them,
and it does not have the rubber 90 (like I found on the drain for 00 vette) there is just a "nozzle" or "ferrule" there,
so I'm concerned I may be looking in the wrong place on the fire wall or I may just have the rubber tube missing and be getting water inside when it's wet outside.
Am I in the right spot? just below the insulated coffee can that looks like part of the freon system???
Tim
Old 11-28-2004, 05:19 PM
Re: Re: 99 front passenger carpet wet
Old Dave, I have wet carpet in the front seat of my 99 suburban on the passenger side, and I think my rubber elbow is missing, but I am also concerned I'm looking in the wrong spot. The drain I'm looking at is not between two metal lines it's next to them and all there is 1/2 inch nipple sticking out from the wall without the rubber elbow. Am I looking in the right area and therefore am I just missing the rubber 90? I also think these are heater supply and return lines not freon.
Tim
Old 11-29-2004, 07:39 AM
Pewter'01SS's Avatar
Pewter'01SS Pewter'01SS is offline
It sounds like you are all missing the drain tube. I had one fall of my truck and I had the wet floor on the pass. side. Go to a dealer and get another one, should clear the problem up.
R.I.P. Andy...It was an honor to have known you.
'01 Camaro SS - SLP Short Throw Shifter, Granatelli Air Lid, blue neon underbody kit
'92 Chevy 1/2 ton 4X4 - 350 w/ 190,000 miles and in desperate need of a rebuild.
'86 Chevy S10 - 350 w/ 400 Turbo trans, B&M Pro-Ratchet, 4.56 Posi, 350 is gone and slowly being replaced.
