Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-18-2004, 12:02 PM
SlowerCivic SlowerCivic is offline
b18c1
Ok I have a question on this b18c1 I want to turbo it and put it into my 95 civic 4dr pos,and I want to change transmission from automatic to manual do you suggest that i go ahead and change transmissions first before swapping so it will be easier or wait till i get the swap.My other question does this place look like a good place to buy a complete engine swap
http://www.importparts.com/shop/inde...cPath=400_1904
157 second quarter mile.
10 min. 0-60
2.7 sec 60-0
79 mpg
Old 07-18-2004, 12:22 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: b18c1
If you do the auto to manual swap now, it will take less time to get the motor in your car once you're ready for it; but you'll have to have your car down twice. And there are cheaper places to go than that site: http://www.hmotorsonline.com/shop/sc...age&item=30009
http://www.totaljdm.com/index.cfm/fu...dm_engines.htm
https://passwordjdm.com/index.php?pa...id=engineswaps
Old 07-18-2004, 12:36 PM
Re: b18c1
so should I get the JDM or USDM engine,Im going to turbo and I heard that if you have lower c/r then its better to turbo
10 min. 0-60
2.7 sec 60-0
79 mpg
Old 07-18-2004, 07:54 PM
CivicSpoon's Avatar
There is no Spoon
Re: b18c1
Either one is going to need good tuning if you're planning on boosting quite a bit, well any boost but especially with that high of compression. Just get a good engine managment and someone who is a reputable tuner and you'll be set with either motor. Personally I'd get the jdm motor, even with the slightly higher compression, because I couldn't see paying that much $ for the motor and making the same amount of hp as the jdm b16a with the usdm gsr (even thought the gsr would have a higher displacement). But that's just me.
Old 07-18-2004, 10:00 PM
T-Racer's Avatar
T-Racer T-Racer is offline
Send a message via MSN to T-Racer
Re: b18c1
[damn thing i had to re-post this]
well before i would get a turbo i would get my manual transmission in, then my JDM engine, and i would go JDM only because it is what I would chose, as it's hard to come by JDM engines in my area. then once i had all that in i would make sure i have a nice set of headers, and a strong exhast system, and then clean up any other engine bay modifications. then when i go to put my turbo in i would get the best performance out of it, but that is just IMO.
My name is Tyler, don't be afraid to call me it.
Originally Posted by BlaZeNSmoKe
So next time I see a deer and I can't dodge it, best believe I'm gon' speed up. Cause he ain't gon' get the best out of a accident with me, no sir.
Old 07-21-2004, 01:21 AM
95TegSE's Avatar
95TegSE 95TegSE is offline
Re: Re: b18c1
i would make sure i have a nice set of headers...then when i go to put my turbo in i would get the best performance out of it, but that is just IMO.
Why would you spend money on a good header, if you're just gonna replace it with the turbo manifold. Waste of money. Only get a header if you're not going turbo, otherwise, stick with the stock one.
From the foothills to the bay, it shall ring, as we sing,
It shall ring and float away; Hail, Stanford hail! Hail, Stanford hail!
Old 07-21-2004, 11:04 AM
Re: b18c1
well I already have the whole turbo kit all i would have to buy is a b18c1 turbo manifold and everything will still work except for maybe the wastegate
10 min. 0-60
2.7 sec 60-0
79 mpg
Old 07-21-2004, 11:46 AM
T-Racer's Avatar
Re: Re: Re: b18c1
Sorry still learning this JDM/Turbo thing. Wasn't sure where the Turbo went, but now i do. damn do i feel like an idiot.
