Old 07-18-2004, 10:22 AM
scbill1 scbill1 is offline
99 Charging system--battery light
Got a battery light comming on, on a 99 GA. I replaced the battery and Alt. The light is still comming on. What would be the next item to check. The positive lead off the alt. dissapears down and i'm not really sure where it ends up i guess this would be next. Any help would be app.
Bill
Old 07-18-2004, 10:40 AM
Red face problem solved
problem solved
Problem solved
Thanks
Old 11-17-2004, 03:46 PM
jschrader666 jschrader666 is offline
Re: 99 Charging system--battery light
Just curious, what was the problem? I replaced my alt/battery and my light comes on still
Old 11-21-2004, 07:46 PM
DRDON DRDON is offline
Re: Re: 99 Charging system--battery light
IM HAVING SAME PROBLEM, ANY SUGGESTIONS? THANKS, DRDON
Old 01-11-2019, 02:45 PM
mwaldrp mwaldrp is offline
Do you remember how you solved this problem?
Old 01-19-2019, 09:16 AM
Tech II Tech II is offline
Newbie, do you have the same year vehicle?
What is the condition of your battery? Old? Recently replaced?
Do you have a voltmeter?
If yes, attach it to the battery....a fully charged bat reads 12.6 volts.....
Crank vehicle, does battery drop below 9.6 volts?
With vehicle running, is voltage above 14.0 volts?
Get engine to normal operating temp....
Turn on lights, rear defogger and blower on high.....
Does voltage drop below 12.0 volts?
Rev engine to 2000 rpms, does voltage rise above 13.0 volts?
