I have a 93 GA GT that started making a loud metal rattling noise while idleing as soon as i step on the gas it goes away. I have removed the serpintine belt started the engine and the noise went away. I replaced the alternator because it squeeked when it rotated and i thought it was the culpret. No such luck.. I have now purchased a water pump and plan to replace it thinking it is the problem. While the belt was off I spun the power steering pump and it didn't make any noise, i also spun the tensioner it too was quiet the only two things i didn't spin were the a/c comp and the w/p a/c because the noise was not comming from that area more from the crankshaft area.. could it still be the harmonic balancer? or do you guys think it is the w/p like I do?
Mike Plano, TX Last edited by mdown; 07-17-2004 at 11:20 PM. |
after more troubleshooting.....
After more troubleshooting.....
I took the belt off agian and spun the a/c comp no noise... and the water pump.. no noise... now i have now idea where the noise is comming from... it's so frustrating... Mike Plano, TX |
Re: 93 GA GT Engine Noise
Check for play in the pulleys. the rattling noise doesn't come from rotation on a pulley, it comes from a bad bearing with strain put on it rotating. I myself would blame the water pump but I've also seen a/c clutches on grand am drive people nuts with trying to fix their rattling car. Before you decide to change the water pump check to see if it's leaking from it's drain hole, it usually does when the bearings or seals go bad.
Does this motor have an idler pulley on a tensioner?....most common culprit that I have seen for front motor noise involving the belt.
I'm an old nerd...just ask my teenagers.... |
Re: after more troubleshooting.....
Hi i HAVE A 93 GT ALSO AND MINE WAS DOING THE SAME THING UNTIL I REPLACED THE AC COMPRESSOR. MINE HAS BEEN QUIET EVER SINCE.
Re: 93 GA GT v6 Engine Noise near belt, need help!
If it does not move, your noise is coming from the Harmonic Balancer jerking backing and forth when it is in motion. This problem drove me nuts trying to find where it was coming from. I hope this helps you with your problem. Good Luck, Dave Kingwood, WV |
