Old 07-17-2004, 08:57 PM
Macdaddy4738 Macdaddy4738 is offline
Send a message via AIM to Macdaddy4738
Exclamation Paint, Primer, Clear Coat, ect. advice
I am probably going to be purchasing a couple bottle of paint. I finally got an airbrush and i want to start airbrushing soon (although i will be forced to use the cans of air for a while )
Anyways...on to my questions.
What brand primer do you reccommend? Ive heard Tamiya is the best stuff...but ive also heard of Automotive primers? What do you personally use?
What brand paints do you reccommend? Id like to know both in Spray cans and in bottles of what brand.
What paints do you airbrush? Enamal, Arcrylic, Lacquer? Whats your choice and why??
What clear coat have you had the best experience with? Ive heard bad stuff about Tamiya and Future Floor Polish and a few others. What brands do you use??
Where do you get your sandpaper from?? Currently im using Testors Sanding films...which run out quick and are pretty small.
What type of glue do you reccommend? I use Testors glue in the tube...but from what i hear this isnt the best to use. I usually just put a bit on a napkin and smear it on with an old knife blade.
What putty should be used for...
A. General purpose...filling sink holes, minor scratches, closing seams. Do i use Epoxy for this?
B. Custom Body work...I heard Tamiya Epoxy is the best...any other brands out there??
Sorry for all the questions. Just being on here and reading stuff has confused me about which brand is better...what to get, stuff like that. If i find anymore questions i will add them in this thread.
Old 07-17-2004, 09:12 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Paint, Primer, Clear Coat, ect. advice
Sorry to do this but, Every question you asked is awnsered in the FAQ, Atleast I think so.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
geofroley geofroley is offline
Send a message via AIM to geofroley
I use Tamiya acrylics for airbrushing. Cleans out easily and sprays really well.
Old 07-17-2004, 09:15 PM
Re: Re: Paint, Primer, Clear Coat, ect. advice
how can all my questions be anwserd in the FAQ when i asked for your PERSONAL EXPERICENCE. I asked for what you use...not for what one single person uses.
Old 07-17-2004, 09:17 PM
pre98zetec's Avatar
Then there is no straight awnser, Everyone use's different supplies. It's all about taste I guess. Buy what you want.
-Josh-
Old 07-17-2004, 09:19 PM
im asking to see what the majority is so i can decide based on that. If your not going to anwser the questions why bother wasting the energy to type it
Old 07-17-2004, 09:25 PM
pre98zetec's Avatar
You want awnser's, Fine I'll give them to you.
What brand primer do you reccommend? Ive heard Tamiya is the best stuff...but ive also heard of Automotive primers? What do you personally use? Duplicolor Filler primer
What brand paints do you reccommend? Id like to know both in Spray cans and in bottles of what brand. Tamiya or Duplicolor
What paints do you airbrush? Enamal, Arcrylic, Lacquer? Whats your choice and why??Acrylic, Easyer to clean
What clear coat have you had the best experience with? Ive heard bad stuff about Tamiya and Future Floor Polish and a few others. What brands do you use?? Duplicolor
Where do you get your sandpaper from?? Currently im using Testors Sanding films...which run out quick and are pretty small. Go to walmart and pick up 400,600,800,1200,and 2000 sheet's, They're cheap
What type of glue do you reccommend? I use Testors glue in the tube...but from what i hear this isnt the best to use. I usually just put a bit on a napkin and smear it on with an old knife blade. Super glue
A. General purpose...filling sink holes, minor scratches, closing seams. Do i use Epoxy for this?Super glue mixed with baby powder
B. Custom Body work...I heard Tamiya Epoxy is the best...any other brands out there?? Read above
-Josh-
Jaymes's Avatar
Jaymes Jaymes is offline
I use Tamiya Acrylics for my airbrush... just painted my windows and they turned out great
I use Krylon for primer... a bit "heavy" as someone said, but works fine if you sand it smooth before painting.
I got my sandpaper from Autozone.
I use Testor's glue in the bottle, however the glue always ends up melting my paint Is this common?
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
urethane clear is the absolute best you can use, its a 2 part clear, you can get it at any automotive paint store
Old 07-17-2004, 09:37 PM
i was planning on using Arcrylics to airbrush because i figured cleaning would be eaiser. I will most likely head to Wal Mart tomorrow sometime and get the sand paper..im in dire need haha.
JTRACING- do you airbrush urethane??
Old 07-17-2004, 09:44 PM
Okiemodelbuilder Okiemodelbuilder is offline
What brand primer do you reccommend? Ive heard Tamiya is the best stuff...but ive also heard of Automotive primers? What do you personally use? I use Tamiya primers as well as Plastikote T-235 sandable gray primer
What brand paints do you reccommend? Id like to know both in Spray cans and in bottles of what brand. Spray paints: I like Tamiya sprays and have had good luck with Duplicolor and Plastikote auto touch up sprays. I've heard good things about the new Testors Lacquers but have not tried them yet. Bottle paints I use include HOK/Black Gold lacquers, Alclad, Tamiya and Testors.
What paints do you airbrush? Enamal, Arcrylic, Lacquer? Whats your choice and why??I use all three.
What clear coat have you had the best experience with? Ive heard bad stuff about Tamiya and Future Floor Polish and a few others. What brands do you use??Tamiya spray clear is good. I also use Duplicolor clear and have heard good things about Plastikote clear.
Where do you get your sandpaper from?? Currently im using Testors Sanding films...which run out quick and are pretty small. I buy my sandpaper at Wal-Mart. I use everything from 220 grit to 2000 grit 3M sandpaper. You can get 1000, 1500, and 2000 in the automotive dept.
What type of glue do you reccommend? I use Testors glue in the tube...but from what i hear this isnt the best to use. I usually just put a bit on a napkin and smear it on with an old knife blade. I use Testors liquid glue in the black plastic bottle some. Also use Ambroid Pro Weld, 5 min epoxy and super glue.
B. Custom Body work...I heard Tamiya Epoxy is the best...any other brands out there?? I use Eversoft Eurocoat automotive polyester body filler for all putty needs. You can get it at an auto body supply store. Use it outdoors because the fumes are potent.
I hope this helps. PM me if I can help you any more. Marc
Completed Pro Touring Projects
...the pro touring experts
Old 07-17-2004, 09:46 PM
Vric's Avatar
Vric Vric is offline
First Time I ear about that !!
Old 07-17-2004, 09:48 PM
pre98zetec's Avatar
Work's wonder's believe it or not.
-Josh-
Old 07-17-2004, 09:53 PM
Vric's Avatar
Tamiya only
Tamiya only for Spraycan. For bottle: Testor, Model Master, Tamiya, Humbrol
All of them. IF oyu have a good Thinner, it's easy to clean your airbrush (Acrylic isn't easier)
Tamiya. Duplicolor is ok too. Stay away from Testor
Where do you get your sandpaper from?? Currently im using Testors Sanding films...which run out quick and are pretty small. Hardware Store. from 320 grit to 2000 grit
Testor in Tube are the first way to scrap a model. Use ONLY liquid Glue. Testor Liquid, Tamiya or Humbrol
I use mainly Tamiya Basic Putty for everything.
Basic putty do the trick too, but Epoxy might be better, but harder to work with
Just remember, saving a buck isn't always the best idea. If you want a perfect model, you need to have skill, but also use the best supply
answer in red
Old 07-17-2004, 09:58 PM
thanks alot!!
I belive i will be ordering tomorrow possibly
