Old 07-17-2004, 07:52 PM
Concord Concord is offline
My 5.7L started missing
My 5.7L started missing when it is under a load or RPMs are greater than 2K. It starts and idles fine. This all started after the fuel pump went out and was replaced. It seems to get worse as the engine warms up.
Old 07-19-2004, 01:50 AM
NWChevyGuy's Avatar
NWChevyGuy NWChevyGuy is offline
Re: My 5.7L started missing
Might check the fuel pressure. I wonder if the "new" fuel pump is faulty and the engine doesnt get enough fuel when it needs it above idle. Good Luck
2001 Silverado
Crew Cab 2500 HD - 8.1 - Allison
6" RCD Lift with 35" BFG Mud Terrains
Airaid Intake - 4" Magnaflow Exhaust - Hypertech Programmer
Old 07-19-2004, 08:25 PM
Fuel pressure is ok
Old 07-22-2004, 02:58 PM
LastOne LastOne is offline
My 98 with the 5.7 has this problem . It has been diagnosed as weak valve springs. I went through the entire ignition and fuel systems first. It seems the weak springs are kinda known in the dealer service departments.
Old 07-24-2004, 09:39 AM
Did the valve spring problem, happen all at once? I have also noticed that if I remove the black box that says vortex from the throttle body the engine won't run, it will run with it on it just misses. This is with the engine warm I don't know about cold yet.
Old 07-24-2004, 06:17 PM
chris2000s10 chris2000s10 is offline
bad plugs / wires / cap and rotor can cause a mis under load conditions
Old 07-24-2004, 10:07 PM
Changed plugs, wires, cap and rotor?
