Old 07-17-2004, 03:51 PM
98GSX's Avatar
98GSX 98GSX is offline
Send a message via AIM to 98GSX
The Worst Motor Removal Ever!
well i am taking my motor out.. i havent taken the transfer case out yet.... so i dropped everything... and i broke one of teh axles while doing so... i dont know how i did....i just did...fuck what do i do now... the motor and tranny have all the bolts taken out that hold them together....cept i need to take off the transfer case... damn what do i do ?!?!!?
RST Eclipse GST: Here's the thing I am a scammer... thanks for the $225!!!!! <----THAS JAKE
^^^ hehehe
2000 Ford F-250 boostin' 30 psi
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
1991 Geo Storm boostin' 10 psi
1998 Eclipse GSX boostin' 16 psi
1991 Oldsmobile Cutlas Calais
Old 07-18-2004, 02:17 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: The Worst Motor Removal Ever!
I'm not sure what the question is. To get the transfer case off there are 5 17mm (M12x1.25) bolts holding it to the tranny, 3 long ones up front, and the short ones in back. Should pop off, though it can get a little stuck on the trannys output shaft. There is also a bolt above the tcase that I'm willing to bet you missed. Its a 12mm head (M8x1.25) and goes from the BLOCK side and threads into the TRANNY. The only "backwards" bolt. Odds are you missed it. Dont go apeshit and break the bellhousing, make sure thats out. Also be sure to remove the drivers side axle carrier bearing in AWDs, 2 14mm bolts (M10x1.25) through the carier into the block. One also doubles as one of the 4 bolts holding the AC compressor adapter to the block. Is that the axle you broke? I think we need more details
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-18-2004, 03:35 AM
98GSX's Avatar
got the 12mm bolt... i need to drop the TFC, fuckign broke that axle you are talking about... but i did take out the two bolts that hold the axle bracket... damnit
^^^ hehehe
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
