Old 07-17-2004, 04:30 PM
burntrice087 burntrice087 is offline
Banned
rough tranny
every time i start my stang up and shift into reverse or drive it revs to about 2k . Out on the road i noticed it shifts gears pretty hard and its been doing this ever since ive gotten the car. Is this normal or is my transmission gonna die soon???
Old 07-17-2004, 04:47 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
I'm assuming by your name you have an 87? What model? Either way, sounds like your either low on fluid or its mighty dirty. Check the level and fill if necessary. If the level is fine I'd suggest a flush, you'd be suprised what a simple flush can do!
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-17-2004, 06:34 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: rough tranny
Make sure you check it when its running and up to temp.
Old 07-17-2004, 10:36 PM
Banned
NO actally the 087 in just a random number i chose....i have a 1998 Mustang V6.. The tranny flush seems like agood idea thanks for the advice!
