Old 07-17-2004, 01:42 PM
cky86 cky86 is offline
Send a message via AIM to cky86
A question with wiring from fuses
Hey I am tryin to install a head unit in my car, ive installed a few before and i know how to do it, but whoever had the car before me had a full system its obvious, and he did some things with the wiring. I couldnt find one of the power wires (12 volt ignition) and its supposed to be blue, there was a blue wire but it is connected to a fuse. Will this wire be the one I am looking for? I have connected it and connected the 12 volt battery wire, and ground and i am still getting no power. Any suggestions?
Old 07-18-2004, 08:22 AM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
Try using a test light to find the fire you need. Turn your ignition on and probe till you wind the hot wire. Then turn the igition off while you are still touching the wire with the test light. If the test light goes off you have found the wire you are looking for
Old 07-20-2004, 05:55 AM
smartjay28 smartjay28 is offline
Send a message via AIM to smartjay28
its not blue, blue is for your remote att or remote amp.
red is for constant (12 volts) and yellow is ignitions
http://www.acura-legend.com
