Old 07-17-2004, 12:21 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
GST - Update... and i need help! (yes i said "i need help")
ok the car is running fine now although i felt no boost at first and i couldnt here the BOV! so i was like WTF and i immediatly thought of a boost leak so i shut down the motor and remembered that i forgot to clamp the LICP to the intercooler so it blew off... well when i put it back on the car started idling really gay... so i checked timing and it was right on! so i took the intercooler pipe back off at it started to run just fine again! WTF is up with that? its starting to piss me off and i'm not liking it... anyways i dont know if the MAS has anything to do with it, i have a spare i am about to check it using that and see if that helps... who knows! i have the MAP sensor hooked up to a vacuum hose that runs directly to the manifold, the TPS is fine... i tested the resistance on that it its good! the CAS is fine... i have excellent fuel pressure and i can hear the injectors firing, spark is just fine... now another thing that has me in a twist, the coil pack and firing order! i am using the stock 2g coil pack and it has always worked just fine. compression is fine, just put a rebuilt head on with all new gaskets last night and now its all acting wierd! any thoughts? thanks in advance guys, any help is greatly appreciated!
Old 07-17-2004, 02:51 PM
duckydsp's Avatar
duckydsp duckydsp is offline
Time for Kevin to come and save the day.
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Old 07-17-2004, 03:14 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Re: GST - Update... and i need help! (yes i said "i need help")
couldnt put it better myself
Old 07-18-2004, 01:05 AM
jdoug jdoug is offline
Send a message via Yahoo to jdoug
Reset the ECU maybe? That seems to work for me from time to time.
J Doug
2003 Mustang Mach 1
1998 Mitsubishi Eclipse GS-T *sold*
Old 07-18-2004, 02:57 AM
kjewer1 kjewer1 is offline
AF - Advisor
The car should barely run at all with the LICP disconnected and a stock MAS. I'll have to think that one over for a bit...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-18-2004, 08:35 PM
EclipseRST's Avatar
Banned
yea thats the thing i dont get! it barely runs when the LICP is connected... purrs like a kitten with it disconnected, i have the stock mas connected... all the sensors are connected! it seem as if its not getting enough fuel! i am pissed and stumped at the same time!!! well any info you have please enlighten! thanks guys
Old 07-18-2004, 11:13 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
sound like somthing with the computer or the MAS
might want to reboot it ,and then re-input ur dsmlink settings or whatever
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 07-18-2004, 11:59 PM
dayna240sx's Avatar
dayna240sx dayna240sx is offline
Banned
Send a message via AIM to dayna240sx
sounds like you need to start over and get a different car...
Old 07-19-2004, 05:16 AM
EclipseRST's Avatar
Banned
dayna... honey... give up, i'm not goin to by a slow WRX or a lesbian Miata! plus they both are just ugly! one looks like a bug, the other a... i cant even describe it, its just ugly with the flip up headlights
and jowmathews...
GO TO HELL!!!
Old 07-19-2004, 06:47 AM
dayna240sx's Avatar
Banned
Jake, I'm not saying get a wrx or a miata...
I'm saying get something that you wont have to waste all your free time having to fix.
Old 07-19-2004, 08:58 AM
EclipseRST's Avatar
Banned
ok well i can get the car to run "ok" but i am still having problems with the idle and rev, while it was running i unpluged the TPS and idle motor/sensor (whatever its called - underneath the TB) and it didnt do anything, didnt improve or worsen anything! so i am guessing one of them if not both are fucked up... but would that be the reason i cant rev the car? wont go past say 3k rpms with the LICP connected.
Old 07-19-2004, 10:35 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Do you have a CEL?
So when it goes upto 3k does it just stay there and build boost? Or does it die down to a low rpm?
For Sale 98 Eclipse GS, 5 spd
Old 07-19-2004, 11:48 AM
LittleGSEclipse LittleGSEclipse is offline
Send a message via AIM to LittleGSEclipse
Hey EclipseRST I had the exact same problem with my car. Then I found out that one of the sensors were bad. I dont really know what the sensor is called but I will tell you exactly where its located. Here goes.....
If you are standing in front of the drivers side front 1/4 panel and looking in at the engine this sensor is located about 8inches under the fuel line that goes into the fuel rail. (I had to remove my fuel line) to get to it. Follow the wire harness down and it is the first sensor that you come to on the back of the engine I believe there are 3 sensors back there. 2 of them are down low more towards your alternator. And the one I am talking about is up higher on the drivers side. Its a pretty big damn sensor. I had a spare one So I just swapped it and then started the car and the problem was all gone. Also sometimes for some odd (dsm reason) the harness that gets plugged into it doesnt seem to fit sometimes and they have a little accordian looking rubber piece that goes around the female part of the harness that gets plugged into the sensor that I had to remove in order to plug it in properly. Check that sensor out. It could be that.
I am new to the turbo aspect so I do not know if it is has anything to do with that. But I have become very familiar with the engine.
Sorry for the long post guys.......
Old 07-19-2004, 11:51 AM
GSTRacerNVUS GSTRacerNVUS is offline
Yea... I have an idleling problem too. It hasn't run right since I replace the TPS, but it's also not shooting any codes out. If a sensor was bad wouldn't a code come out?
Old 07-19-2004, 03:29 PM
EclipseRST's Avatar
Banned
Re: Re: GST - Update... and i need help! (yes i said
Originally Posted by ashah000
Do you have a CEL?
yea it builds boost just fine... i had 1 code and that was O2 sensor... cleared that and it hasnt come back yet today and it still runs like shit!
