Old 07-17-2004, 11:02 AM
1989_cash_eater's Avatar
1989_cash_eater 1989_cash_eater is offline
Grease ball joints/Messed up injectors!
I was wondering how to go about greasing the ball joints in my 89' civic hatch DX? Can anyone help?
Also the car still idles high in netural, like around 1700 rpms, and every now and then, when I go to start to car, it won't start until I give it a little gas. I checked the ECU and in gave me code 16 I think. Faulty fuel injectors? Could this be the cause of the high reving, or is it just the trottle cable? thanks.
"If you can read this...I'm Parked!..............Or broke down."
Old 07-17-2004, 04:33 PM
BullShifter's Avatar
Re: Grease ball joints/Messed up injectors!
Ball joints, tie rods, suspension bushings should all be lubed with multi purpose grease. They are all sealed so you just spray the area with an aresol can.
Have you adjusted the idle correctly?
Find all your answers here - http://www.binghamtonlife.com/manual/2gsm/default.htm check the fuel/emmisions section
Old 07-22-2004, 06:40 PM
Would white grease in a spray can work???
