Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 07-17-2004, 10:05 AM
rtc5 rtc5 is offline
computer wont pass inspection
When I try to have my 98 ford ranger inspected for the new NJ DMV computerized inspection it comes up with an error on the inspection computer that it experienced a communication failure with my trucks computer. New Jerseys new inspection laws require their computer to be hooked up with the trucks OBD II system in order to perform emissions testing. Yet when I take my truck to my mechanic, he can read all the engine diagnostic info from his scanner and says he has no clue why the inspection station can't communicate. Why would it work on one and not the other, I have no codes and all systems show up as ready. I've tried to get inspected three times at different stations with the same results.
Im not sure anyone has heard or knows anything on this problem since it is a new system and is probably rare in other states but im afraid how much it may cost if I end up replacing the computer.
Old 07-17-2004, 10:11 AM
2000mudder's Avatar
2000mudder 2000mudder is offline
Re: computer wont pass inspection
wow. i was gonna say maybe its the test stations link but 3 diff places.not quite sure how to help if mechanic can read it ok.
Old 07-20-2004, 07:20 PM
got it fixed
I guess the fourth time is a charm, after stumping a few mechanics with my problem I tried another inspection station and after messing with the connector he got it to connect. He said the connector they use does not have a very tight fit so he had to move the connector around until he got a signal. Once that was done the truck passed inspection without a problem but what a pain, almost 2 months running around trying to find someone to fix this and its just a bad harness they use.
Old 07-20-2004, 08:32 PM
mikieem mikieem is offline
I know what you mean with the NJ laws now. This state keeps getting worse. I would just say take it to a local mechanic that hopefully you know that does inspections and pay them to put it in if you cant pass you the state. BTW, where NJ are you from?
Old 07-21-2004, 12:42 PM
2000mudder's Avatar
i would try to contact someone in the state vehicle dept and gripe about all the time and money you spent trying to get your COMPLIANT vehicle checked on thier faulty systems!!!
Old 07-22-2004, 03:12 PM
200mudder, you have to realize one thing about new jersey, this state is a bitch at everything, so complaining won't do you any good. All this state cares about is money.
Old 01-04-2005, 01:21 PM
ranger04 ranger04 is offline
I would just move to a state that doesn't make you go through all the bullshit
Old 01-08-2005, 03:50 PM
XLT03 XLT03 is offline
Come to California. What you guys have in NJ is nothing. California smog tests has what you have but it also requires the vehicle to be on a dyno so they can measure the emissions at idle and under load. Best advice before taking a vehicle for smog/DMV test is change your air filter, look around to make sure all vacuum lines are attached and you have a gas cap that works. And most important make sure your engine is at normal operating temperature.
Old 01-12-2005, 09:38 PM
brandonbuilding brandonbuilding is offline
goto checkers and buy the emission pass stuff, 10 bucks and its guaranteed or your money back
