Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 07-17-2004, 08:58 AM
arnaud arnaud is offline
no starting, Fuel related?
Hi,
I have been having a starting problem with my Mazda Etude (seems to be the protege in the US). Has happend 3 times now and always in the morning. Will turn over but not start. The first time it started only after I removed the fuel pump (inside the fuel tank) and put the same pump back in. The second time was about a month later (after being driven every day). I replaced the fuel filter (very dirty) but would still not start. When opening the fuel tank to remove the pump, I noticed that some pressure was released from the tank. I started the car up and it started and ran fine for 2 days. This morning the same happend but there was no pressure in the fuel tank (tank was full). I disconnected the wires to the fuel pump, turned the engine over a few times, then connected the wires and the car started. It seems to me to be a problem with some pressure buildup near the injectors. This is a very puzzling problem.
I don't know if this is related, but the engines idles very roughly just after starting. This has been happening long before the starting problem. I sent it to Mazda for the rough idling, but (surprise surprise) they only managed to set the idle speed too high.
Any thoughts on this would be appreciated.
Thanks
Old 08-26-2004, 01:19 AM
GAProtegedriva97 GAProtegedriva97 is offline
Send a message via AIM to GAProtegedriva97
Re: no starting, Fuel related?
I had the same problem with my car. If I would get it to start , it would take me a long time for me to.. Finally replaced fuel pump and right now , no further problems have happened...
