Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 07-17-2004, 02:02 AM
mab6680 mab6680 is offline
rear wiper
the rear wiper on my 2000 xls is not working properly the wiper only touches the half of the window it will come off the holder on the gate and not touch the window intill the wiper is pointing strait up the make contact with the window and only wipe half the window any clue what coused this or how to fix
Old 07-19-2004, 02:06 AM
nitenrustinarmor nitenrustinarmor is offline
Send a message via AIM to nitenrustinarmor
havent had this problem but have seen it on a few maybe try to replace the wiper arm? not sure it will help but if the spring is bad it wont put pressure on the wiper to push against the window hope its of some help
Old 07-21-2004, 11:56 AM
2000XLTV8 2000XLTV8 is offline
Re: rear wiper
I have the same problem with my 2000 Exploere (along with some other problems). Did you get any advice or try anything??
Old 07-22-2004, 06:06 PM
Car Pal Car Pal is offline
Re: rear wiper
it is the arm,corrosion builds up in the joint
Old 07-22-2004, 06:15 PM
Re: rear wiper
give it a shot thanx let u know what happens
Old 07-23-2004, 09:44 PM
Re: rear wiper
there is a cover at the end of the arm and it just lifts up. then a 1/2 in. nut. if you can take the nut off you can remove the arm and really clean it out.
Old 07-26-2004, 08:04 AM
Re: rear wiper
sorry rained all weekend will post my findings by the end of the week
Old 07-27-2004, 06:16 PM
Re: rear wiper
ok so i replaced the wiper arm and it still only touches half the window any other ideas
Old 07-28-2004, 06:58 PM
Re: rear wiper
i usually bend the arm, just a little.did you replace the wiper arm or the blade?
Old 07-28-2004, 09:01 PM
02n96exploder 02n96exploder is offline
mine took some WD-40 and just worked it to lossen it up. Did also put on a new blade and it was fine after that!!!
Old 07-31-2004, 01:41 PM
Re: rear wiper
i trird bending the arm just a little bit but the blade got stuck at the edge of the window and did not go any further had to bend it back
Old 08-05-2004, 03:59 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: rear wiper
ford now has an updated part number for an arm with a stronger spring - it is much better but still misses spots - I have had good luck removing the original arm spring and replacing it with an old spring from past brake jobs
-=-=-DANE-=-=-
