Old 07-16-2004, 08:44 PM
pro_am pro_am is offline
Send a message via MSN to pro_am Send a message via Yahoo to pro_am
How much HP? Please help!
Okay, I have a very knowledgeable friend, and he is usually pretty right on with things. But when i suggested this engine build up to him, he said it would put aut about 225hp and 300 lb ft of torque. I think that is a little low, so if you would be so kind as to give me your estimates I would greatly appreciate it.
PS This guy however, gains 15hp from a cold air intake on his vortech power '97 gmc (bullshit my friend)
4 bolt 350 block, standard bore
pink rods, reg 5.7
10.1 pistons
Fuelie/Camel Hump/double hump heads
Crane cam .510/.510 about250 duration (i think)
Air gap intake
Holley 650 carb
headers, pretty open exhaust
MSD Ignition, decent distributor
What do you guys think it will turn out?
thanks a lot
Jake
Old 07-16-2004, 10:18 PM
Deadcarny Deadcarny is offline
Re: How much HP? Please help!
You really need the valve sizes for the heads. do you have casting numbers for which double hump heads you are using? what is the LSA of the car, what is the Itake ceterline? what are the durations at .050"? I will load all this into my desktop Dyno if I have the right info.
1995 Camaro Z28, 383ci 485+hp 495ft-lbs SOLD!!!
1965 Ford F100
1967 Chevrolet Impala (Sold)
1972 Chevrolet Chevelle (Sold)
1972 BMW R60/5 (Sold)
1980 Harley Davidson FLH
1987 Harley Davidson XLH
1992 Astro EXT AWD
1992 Chevrolet Cavalier
2000 Monte Carlo SS Pace Car 1087/3222 (Sold)
2001 Pontiac Sunfire
2002 Trailblazer LTZ (Sold)
South Carolina F and Y Bodies
www.SCFYB.com
Old 07-16-2004, 10:20 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
bore, stroke?
Old 07-16-2004, 10:29 PM
He said standard 350, so 4"/3.48 stroke
1965 Ford F100
1992 Astro EXT AWD
www.SCFYB.com
Old 07-16-2004, 10:32 PM
sorry missed that part, wasnt sure if it was stroked or not...
Old 07-16-2004, 10:51 PM
Okay, I loaded this into my Desktop Dyno with the little info given to me. here is what I inserted:
350 block, 4" bore, 3.48" stroke.
Low Performance Heads with stock ports/valves (Camel humps are pretty much Low Perf on DD)
1.94" Intake/1.50 Exhauat valves
10:1 CR
650 cfm
Dual plane manifold
Small Tube Headers/open exhaust
Hyd lifter cam(specs @0.050") .510 lift, 254/256 dur, 116.5 Lobe centerline, 22 degrees overlap
With these Generic settings I came up with a peak of 313hp at 5500 rpms and 324ft-lbs at 4500 rpms.
1965 Ford F100
1992 Astro EXT AWD
www.SCFYB.com
Old 07-16-2004, 11:06 PM
in Desktop Dyno my Engine has me peaking 497hp @6000 RPM's and 481ft-lbs @4500 RPM's. Since my at the wheels numbers are 411hp @6000 RPM's and 418 ft-lbs @ 4500RPM's that means I have a 17.3% Driveline loss up top and a 15% loss down at the lower RPM's. Since I have exact FLow numbers on my heads and exact specs on my cam, the DD should be near perfect accuracy.
1965 Ford F100
1992 Astro EXT AWD
www.SCFYB.com
Old 07-18-2004, 07:32 AM
Whow you guys work well. thanks a lot for the help. I just got a copy of desk top dyno myself, i'm looking forward to getting started with it.
Jake
Old 07-18-2004, 12:17 PM
yeah its a good tool for getting a ballpark figure of what you will be running with various parts. if you have all the data DD is generally accurate to within 10-15 HP...
