Old 07-16-2004, 08:20 PM
jpwindsor jpwindsor is offline
Engine ping 2000 GT
Hi, new to this forum, I have a 2000 Mustang GT 4.6L Auto that seems to have excessive engine ping over approx 1/2 throttle. First I thought it was the Jet Power Programmer, took it out, same problem. Have been using premium fuel. Any thoughts on this or anyone else with a similar problem? Thanks.
Old 07-16-2004, 08:39 PM
vette_7t9 vette_7t9 is offline
Definately not engine knock. to be honest, 4.6s lack compression! the ping can be from mis aligned timing belt tho, which i highly doubt. I am not good with pings, so take my advice at your own risk.
Old 07-17-2004, 12:02 AM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
stop using premium. switch back to regular. premium gasoline is for motors that make aobut 10 or 10.5:1 compression, typically. i'd advance your timing a couple degrees too, just to be safe. you're just asking for detonation here.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 07-17-2004, 06:29 PM
Cobra01TT's Avatar
Cobra01TT Cobra01TT is offline
Re: Engine ping 2000 GT
GT's don't have any need for premium. Hell, Ford says premium only on my Cobra (higher compression), but it'll run fine on 85 without any detonation.
2001 Ford Mustang Cobra - Straight piped and loud as hell
2002 Yamaha R6 - Micron exhaust
1987 Chevy Corvette Convertable A.K.A. - The Pimpmobile
Old 07-18-2004, 02:21 AM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Make sure your EGR valve is functioning properly.
Too high octane won't immediately cause detonation, and I'm scratching my head over why someone would recommend advancing your timing when you are already pinging.....
Anyway, get the EGR checked, and pull codes, and see what you come up with.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 07-18-2004, 08:13 AM
brentmcq brentmcq is offline
Are you sure it's an engine ping? Could be a small exhaust leak.
2000 GT 4.6L 5spd, BBK cold air, BBK 75mm TB, Bassani catted X-pipe, (no headers) FM catback, 390 gears, SCT chip, Steeda Pulleys, ported stock plenum, Comp Cam XE262AH. RWHP 260, Torque 282
Old 07-19-2004, 03:08 AM
motor_head_429 motor_head_429 is offline
Re: Re: Engine ping 2000 GT
I was just thinking that.
Using premium fuel should not cause detonation on that car.
If I'm not mistaken the JET programmer advances your timing. Even though you said you took out the programmer, I would still check the timing just in case. I'm not too familiar with this programmer, but I guess it could alter your stock settings even though it's been taken off.
