Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-16-2004, 07:52 PM
robcwell robcwell is offline
Jeep 5.2 no start
Hello everyone ive got a 93 JGC 5.2l that has no spark, I thought it was the pick-up but it was not, But one of the connector pins coming from the the pick Up looked black (i know not good) ,so i installed new Pick up,(cap an rotor (needed it vert badly), and still no spark , Coil checked out good ,so im thinking its a Ignition Module or its in the ECM does anyone know if theres a ign/mod for this model, and if so where, or if the ignition signal comes from the ECM
thanks for any help
Rob...
Old 07-16-2004, 10:21 PM
Dale Aeppli Dale Aeppli is offline
Re: Jeep 5.2 no start
thanks for any help
Rob...
HI SOUNDS LIKE YOU MAY HAVE A BAD CRANKSHAFT on v/8's its on the rear of the right cylinder head right above the starter at the end of right cylinder head hope this is helpful DALE
[email protected]
Old 07-17-2004, 01:19 AM
im not sure what you mean by "crankshaft" being bad do you mean a crankshaft position sensor, this 5.2 L engine has a distributor does it still use a crankshaft pos. sensor?
thanks for the quick reply
Rob
Old 07-17-2004, 10:29 PM
Rob
HI, IF YOU EMAIL ME DIRECT I'LL SEND INFO. ON CHECK SENSORS YES I MEANT CRANKSHAFT POSITION SENSOR. IT ON END OF CYLINDER HEAD RIGHT SIDE. RIGHT ABOVE THE STARTER dale
[email protected]
