Old 07-16-2004, 06:46 PM
pcosmasc pcosmasc is offline
Wink lumina needs help? will you help me veronica
My lumina seems to not want to accelerate. I was going 70 mph and all of a sudden it began losing speed. I pressed on the gas pedal but it did not help. It coasted to a complete stop. The engine never turned off either. There was power in the car but i was unable to accelerate. The gas pedal was dead. This has happened 3 x. Can anyone out there tell me what the problem is ? Thanks a bunch....
Old 07-16-2004, 09:37 PM
98Lumina's Avatar
98Lumina 98Lumina is offline
Banned
Send a message via AIM to 98Lumina
Re: lumina needs help? will you help me veronica
Duly noted.
Old 07-17-2004, 02:19 AM
tigger81 tigger81 is offline
There might be a problem with the fuel pump. Is the car start now? If so does it run good while it's in park, and goes to crap when you only try to drive it? Reply back and I'll try my best to help you.
Old 07-17-2004, 11:47 AM
Yes to all your questions. Does not go to crap. I have not changed the fuel pump yet. Car ran fine yesterday. Maybe some isolated incidents. But scary. Thank you tigger 81.
Old 07-17-2004, 01:04 PM
Kooterskkar Kooterskkar is offline
Send a message via AIM to Kooterskkar
You might have snapped the throttle cable.
Old 07-17-2004, 01:08 PM
If i did snap the throttle cable would the car still intermittently run fine?
Old 07-17-2004, 01:14 PM
hmmm nvm then... Did your check engine light come on when it did that?
Old 07-17-2004, 02:01 PM
No. Bye the way i am not snapping at anyone it is just the way i come across. To the point abrupt.
I have provided all the specifics of the situation. I have left out nothing!!! Thanks again for any suggestions.
Old 07-17-2004, 11:39 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
check all grounds, maybe a bad throttle position sensor, or bad ECM itself. I dont know what else to say. Good Luck.
Old 07-18-2004, 02:20 AM
The only reason it would do abolutely nothing is if the throttle wasnt opening. At all. You are sure that is does absouletly nothing when you press on the gas but it will be fine after you stop? You said there was power but you werent able to accelerate. That doesnt make any sense. If there was power you would surely accelerate. If you could not accelerate then there could be no power. So which is it? When you hit the gas does it do anything at all? Any difference in the sound of the engine? Anything at all?
Old 07-18-2004, 07:43 AM
amcweeny amcweeny is offline
Maybe its an intermittent transmission problem. If the engine runs but you're not going anywhere...
Andy
Old 07-23-2004, 01:50 PM
What I mean by power is the car is on. Stereo is on. Windows roll up and down. Etc... However the car will not accelerate when i step on the gas pedal. It won't acccelerate. it has no effect. it just coasts to a stop. I turn it off and proceed. It has happened to me 4 x in the last week. When i hit the gas it does nothing at all. there is no different sound in the enging. No rpm movement. No rev. No nothing. It is as if the gas pedal itself was just disconnected.
Old 07-23-2004, 01:52 PM
No check engine light appears.
Old 07-23-2004, 08:19 PM
So the engine is dying when you are moving. You stop, turn the key off, restart the engine and continue on. Correct?
Old 07-24-2004, 03:40 PM
The engine is not dying. It is on. It will not accelerate. The engine is fine. I turn off the engine after it coasts to a stop while the engine is running because i have no acceleration.
