Old 07-16-2004, 04:55 PM
DiGiTaLEcLiPsE's Avatar
DiGiTaLEcLiPsE DiGiTaLEcLiPsE is offline
Send a message via ICQ to DiGiTaLEcLiPsE
Need help.
I'm going to try and build my first bodykit for my FTO. I was planning to do the veilside bodykit but I keep looking at it and I don't know how to do it?
I don't know which parts I should cut off and whatnot. Maybe someone could help me out to convert this
To this
Help will be appreciated.
Old 07-16-2004, 05:27 PM
supratuner's Avatar
i dont have to much in the way to help you, but ive heard froma lot of people to start out small, and veilside kits are pretty tricky, if u can pull this off, i bow down to you
i jumped in too deep working on my RB26 integra, hopefully i can make it look somewhat good
good luck, and theres a lot of great people here that should be able to help, surprised im teh first one posting
Old 07-16-2004, 05:47 PM
dread_darven's Avatar
dread_darven dread_darven is offline
Send a message via MSN to dread_darven
Re: Need help.
Here is my approach:
with the front bumper; you can cut the lower part from you old bumper, bellow the red line in the pic
Then this part needs to be cut away
then the lower part of the veilside bumper needs to be made with styrene and putty (A) .
The B part needs to be cutted and moved back, then fill with putty (it's hard to explain)
Thats the way i should have done it i guess.
In progress: VW Golf mark II, Reiger GTO Evolution *Updated: September 2 2004*
Old 07-16-2004, 06:02 PM
Cool thanks!
Hmm... I was just thinking about cutting those parts.. but what to cut it with? Just a regular modeling knife?
Old 07-16-2004, 06:06 PM
Re: Need help.
I must say that i use a dremel with a cutting disk to do this stuff. but if you have patience you can use a good hobby knife. ps. i think there is a faq around here about cutting doors and hoods and such, it could help
[EDIT]here it is http://www.automotiveforums.com/vbul...threadid=61545 [/EDIT]
Greets
Erik
Old 07-16-2004, 06:43 PM
Vric's Avatar
Vric Vric is offline
Re: Need help.
you can cut like a butcher, anyway, there is a lot of putty and styrene work to do.
Cool project, hard one for starting, but it does look good
Old 07-16-2004, 07:53 PM
OK Here I go.. I'm just going to use a modeling knife...
More help will be appreciated.
UPDATE : I CRACKED THE MODEL! Oh well.. guess I'll have to fix it with some putty.
Old 07-17-2004, 01:58 PM
blueboost's Avatar
blueboost blueboost is offline
Re: Need help.
you need a dremel to remove that much plastic, unless you want to go mad.
Old 07-17-2004, 02:16 PM
I did it.. lol.. I used a sprue cutter and cracked a bit of the plastic but I can fix it easily..
Also have a progress thread so you can check it out. Not much progress yet.
