Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-16-2004, 04:12 PM
jsprack5 jsprack5 is offline
Angry HELP! stalling prob. w/ 3rd gen maxima
i have a 92 maxima se. im wondering if anyone else has been having this same problem.... while driving the motor will just cut out, then it will be fine. sometimes when it cuts out it stalls, but it starts right back up. other times when it cuts out(the rpms just drop, and it wont go) ill down shift and it will come right back. does anyone else have this problem with the motor just cutting out and coming back and cutting out over and over again? someone please help, its driving me crazy!!!
Old 07-30-2004, 05:13 PM
jyroach jyroach is offline
Re: stalling prob. w/ 3rd gen maxima
help i have same prob, runningout of $ to repair, not safe to drive, did you fiqure it out?
Old 08-01-2004, 02:46 PM
Tmaxismessedup Tmaxismessedup is offline
I also have the same problem on my 89 SE, the car never stalls but has a flat spot in the accelerator where the car just dies until I let off the pedal, once I hit the gas again several times it will seem to go as normal. Sometimes the RPM's will just drop and then start to fluctuate as if a sensor or switch is going off and on. I took it to a shop and they said it was the cap. I replaced the cap and it made no difference. I have also tried the following, replaced the throttle position sensor, fuel filter, tranny fluid, spark plugs, checked the computer codes and nothing changes. I was reading another forum and they suggested the crank sensor so I may try that and see if it makes any difference. I have been messing with this for over a month and am at my wits end.
Old 08-03-2004, 09:17 AM
TSMONEY TSMONEY is offline
Hopefully This Helps Yall..i Have A 93 Se This Is Only For The Dohc V-6,,i Called Nissan To Order Parts The Service Guy Asked Me About The Problem I Told Him I Changed The Air,gas Filter,no Differince I Told Him I Also Replaced The Plugs,,he Stopped Me And Said What Kind I Told Him Bocsh Plats..he Said To Get Them The Hell Out And Replace With Ngks Platnums...i Went To The Dealershipand Purchased 12.99 A Piece Ouch.. But The Problem Has Gone Away For Now Its Been 4 Days And No Cut Offs...it Feels Great..
Old 08-05-2004, 12:31 PM
tlaico tlaico is offline
Re: Re: stalling prob. w/ 3rd gen maxima
I have a 2000 max se. Same/Similar problem. When on the highway,
I push in clutch as I am coming to red light (for example)
Tach goes down and keeps on going to zero - stall !
I re-start - all is ok. Drive for a while .. could be hours, or a couple of days later. coming to light, push in clutch - Tach starts to drop and
again stalls again. It is in Nissan service now as I write this, I just got
a call that they cannot get it to stall. It is intermittant and frustrating !!!
Is there an idle control valve or unit on these cars?
What can this be? Even Nissan does not seem to know - or isn't saying.
Old 08-06-2004, 05:01 PM
its been a week now and still no more stalling nor hesitating car is running well,,,use the spark plugs nissan recommends for your exact model and engine size and only use the ngksssss..
Old 08-07-2004, 01:52 AM
turk66460's Avatar
turk66460 turk66460 is offline
Send a message via AIM to turk66460 Send a message via Yahoo to turk66460
Check the MAF.
Old 09-08-2004, 10:15 AM
hey "TSMONEY" did the new spark plugs really work, before i spend even more, you guys out their help this poor girl, also " turk66460"what is a MAF???????????
Old 09-08-2004, 06:06 PM
turk66460's Avatar
Mass Airflow Sensor. Its located next to you air box.
