clock
All of the sudden the digital clock in the 2002 elantra just changed to 3 hours off. For this to happen, something had to power down, but what? Also, the buttons to reset the time won't work now either. Anybody have a clue and an idea on how to fix this?
My clock has the same problem. I can't get the adjustment buttons to work.
Re: clock
Must be that Y2K bug finally catching up to their pre 90's technology used in the clocks...hehe ![]() But seriously you may just try disconnecting your battery for a few minutes and seeing if it resets. If it doesn't your clock...which is almost entirely a circuit based on an ASIC, will likely need replacement. If by chance your out of warranty you can get one from a scrap yard online cheap. Good Luck, Jason |
Re: clock
I thought about disconnecting the battery and resetting the clock, but if the buttons still don't work, then I have a blinking 00:00 instead of an hour off reading.
The car is still under warranty and has a recall that needs to be taken care of, I'll just take it in and get it all taken care of. I was trying to remove the instrument panel cover to see the clock, but it wouldn't snap off, and I didn't want to break anything. I removed to screws above the speedometer and two in the ashtray. Are there more? |
Re: Re: clock
Jason |
Re: clock
Now, everytime you step on the brake, the dashboard lights come on. It's very annoying. What could have gone wrong to have all this start happening? I guess I'll just take in to Hyundai for repair before the warrenty expires.
Re: Re: clock
Sounds like a short. If your brake lights turn on your parking or headlights could be as simple as a shorted taillight bulb or relay. In hindsight does this issue occur in the other direction? does the second element(brake lights) come on with the normal running tailights? Jason |
Re: clock
nope
Re: clock
I see bad bulbs do this all the time
first i would starting with the left light unplug the bulds one at a time testing to see if dash light comes on after removal i am confident you will find that after removing one of the bulbs your concern goes away , then replace that bulb |
