Old 07-16-2004, 06:15 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
idle control tip from other thread does it work on 99 2.0?
Someone suggests on the idle control (on top of the intake manifold looks almost like a mini starter) that you can take it off the car and clean it up and lube it up with wd-40 and your good as new.
New from autozone this unit is $59.00.
My car seems to do like the other post mentions the idle is not the greatest more so with a/c on. and those symtoms suggests the idle control. Is there a way to conferm this problem or just try the wd-40. If I were to try the wd-40 would I need a new gasket or could I just rtv it?
Old 07-16-2004, 08:23 AM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: idle control tip from other thread does it work on 99 2.0?
only a dealer can confirm. I'd cleaned mine out with WD-40 and canned air. Also look into changing your plug wires, made a world of difference for me, more than cleaning the IAC.
Old 07-16-2004, 08:28 AM
chevyn0va1's Avatar
Re: Re: idle control tip from other thread does it work on 99 2.0?
Thanks for the insight so you actually did the wd 40? can you give a rundown what you did. Did you take it off to do it? As far as plugs go yes I did do that in fact I used to have a "buck" everytime I went into 2nd gear but after a tune up the buck went away. I did some reading and found that buck was from a breakdown of spark IE spark leakage which I found at night that I had. Even after the tune up the car is crappy then I'd like at idle.
Old 07-16-2004, 10:10 AM
Jet-Lee's Avatar
Banned
I simply took it off (reused the gasket) flipped it over, sprayed WD-40 into it, about half full on each side, then shook really hard, then sprayed out with canned air (cuz I don't have a compressor). Then repeat...lol...I used about a half a can of WD-40 and almost all of my canned air (the big cans). Then I just slapped it back on, didn't even wait for the WD-40 to dry (it's flammable anyway).
Old 07-16-2004, 02:32 PM
chevyn0va1's Avatar
Thanks for the tips its a a shame it didnt help you much you said though I hope i get lucky. Have you ever cleaned the intake/throttle body while you were there?
