Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 07-16-2004, 01:26 AM
Dave3647 Dave3647 is offline
94 4.6 overheating with air on
I have a 94 4.6 thunderbird that runs fine until I get on the interstate with the air on and the temp rises almost to the red. If I turn the air off the temp goes back to normal. Just driving on city streets it will not run hot even with the air on.
I have replaced the water pump,thermostat,and coolant recovery cap. I replaced the electric fan a few years ago due to the fan making noise and the blades vibrating to much.
I think the fan is operating on both speeds but not sure.
There is no water in the oil or oil in the water so I'm pretty sure the head gasket is ok.
Any suggestions?
Old 07-16-2004, 05:14 AM
The ORIG. Dig. Oxy's Avatar
The ORIG. Dig. Oxy The ORIG. Dig. Oxy is offline
Re: 94 4.6 overheating with air on
The radiator might be plugged up.
There might be lots of crap in the AC condenser fins, as well. Though, generally thats not the case.
Anything Worth Shooting, is Worth Shooting Twice
Ammo is Cheap. Life is Expensive.
Old 07-17-2004, 09:47 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
But if your a/c pressures aren't right, you can cause the condenser to run hot leading to overheating.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 08-24-2004, 03:29 AM
msbs77's Avatar
msbs77 msbs77 is offline
Send a message via Yahoo to msbs77
Had the same problem......had some dirt in the hoses....take it to a place that can "vacuum" out all the dirt......draining and refilling will not fix it.....it needs to be sucked out.......combined with a 180 thermostat....runs cool all day long.....the temp get over 100 constantly during the summer here.
Old 08-25-2004, 02:51 AM
Mike75 Mike75 is offline
How about your radiator cap? If it rusts up enough, couldn't that lock up the spring mechanism, or even weaken it for that matter? Idk, just a thought...
