Old 07-15-2004, 11:40 PM
nrlemons's Avatar
nrlemons nrlemons is offline
¿Steering Pop?¿?
Recently our tahoe has developed a "popping" sound whenever turning very sharp. It doesn't happen if you turn the wheels hard without moving the car, but when you start to move (turning into a driveway or backing out of a parking spot, stuff like that) the steering willl make a popping sound. Has anone else had or heard of this problem before?
Old 07-16-2004, 11:14 AM
Keyser Soze II Keyser Soze II is offline
it sounds like the infamous "steering klunk" it is a quick fix at your dealer. You can also search the edmunds town hall for "steering klunk" or "clunk" and get a lot of info
Keyser Soze
2002 Tahoe LS
5.3
Pewter
Tan Leather
3rd row (in storage)
no dvd
no sunroof
no onstar
bought used w/27k miles
Old 07-17-2004, 10:36 AM
mustgo69 mustgo69 is offline
Re: ¿Steering Pop?¿?
New streeting shaft is what they replaced on my suburban.
Old 07-17-2004, 08:36 PM
DFarrar DFarrar is offline
I heard that sound for a little while, then while driving down the road one day i heard another pop, then my wheels went in different directions. What happened was the nut the holds the tie rods to the front wheels unscrewed thus having no control over my front wheels. Pretty scary if you ask me. I had it fixed and so far no more sound. Chevy needs to install pins on these nuts so they dont come loose. The sound is probably from the slack on the loose rod. Either way, check those nuts, theres no real way to tell how loose they can get
Old 07-18-2004, 05:35 AM
jthomp23777 jthomp23777 is offline
I agree along with KeyserSoze II as he put it the infamous steering klunk. My 2001 Hoe did the same thing when turning, more prevelent to left turns. The dealer did fix the problem and thier service department stated its a flaw though it only it deserve a bullentin on it and no recall because its not a safety issue.But I agree with the other thread that it could be a safety issue and should be fully checked. I just thinking along that it sounds exactly what mine did. Anyway the cure as I was told that there is a steering u-joint of some nature that gets dry and needs grease attention. Good luck, let us know what the outcome is.
Old 07-18-2004, 09:12 AM
nrlemons's Avatar
I did as keys said and went the edmunds town hall place and found another guy who had the same problem, he said he would send me the service bullitin in a .pdf. After i get that ill take it to the dealer and see what they say.
Old 07-18-2004, 01:10 PM
Re: Re: ¿Steering Pop?¿?
For what it's worth - when I took mine in the dealer immediately knew what it was and they had it fixed within 2 hours. They do a lot of these......covered if still under warranty of course.
Keyser Soze
2002 Tahoe LS
5.3
Pewter
Tan Leather
no dvd
no sunroof
no onstar
