Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-15-2004, 11:04 PM
MARKNY MARKNY is offline
OIL CHANGE QUESTION 1997 Max 3.0
Do i have to remove anything (Covers) to change the oil filter? How many Qts does the 3.0 24 valve engine take? Last question--should i use 10W30 10W40 Thanks.......
Old 07-16-2004, 12:26 AM
THT THT is offline
Re: OIL CHANGE QUESTION 1997 Max 3.0
You don't have to remove any covers but it's recomended that you do. You can bend it back if you don't want to though. If you're changing the filter as well, use about 4.5 qts. If it's just an oil change, four qts will be plenty. And use 10W40
~THT
Some people call it an obsession; I call it my Maxima.
Old 07-18-2004, 10:17 PM
Jolly97Max Jolly97Max is offline
You'll get better mileage with 5-30. Also may want to use synthetic oil to maximize engine life and ease cold weather start-ups. (Don't use Castrol Syntec, It's not really synthetic)
Old 07-18-2004, 11:04 PM
SEMatt SEMatt is offline
Send a message via AIM to SEMatt
You have to watch with synthetic on higher mileage engines though. With the carbon and sludge build up that may be what is keeping alot of the engine seals closed such as the front or rear main seal. If you add a thinner oil such as synthetic which also has greater engine cleaning qualities, it may move that sludge away and cause a major and costly oil leak.
1995 Nissan Maxima SE
Pearl Blue
AT
Clear Corners, Magnaflow Muffler, 2 Infinity Reference Speakers, 2 12" JBL sub, RF Punch Amp, Sony Headunit, and more...
Old 08-03-2004, 02:18 AM
ZaxMax90 ZaxMax90 is offline
Send a message via Yahoo to ZaxMax90
hey whats up...use 10w30 and put 4 and 1/2 quarts..no more no less..do not go buy the dip stick it will give you the wrong reading on it..and the oil filter should be right next to the passenger tire in front...you shouldnt have to move anything...
