Old 07-15-2004, 09:12 PM
steve22 steve22 is offline
Arrow 98 escort Battery Question
I had my 98 escort idling with the key turned in the "accessory" position (the one where you can still run the radio and A/C) for about 2 hours. Afterwards I tried to start the engine but it would not start. I tried two or three times and it failed to start. So I called a friend and he came to give me a jump. It worked and the car started up fine and has been fine ever since without any other starting problems. This was 5 days ago since it happened (7-10-04). I just wanted to know if there was any real problem with the car or battery? Or could I have just waited for the battery to "regroup" and then try to start it? Should I have done something differently then getting someone to jump the battery?
Old 07-15-2004, 09:23 PM
JZ94 JZ94 is offline
Re: 98 escort Battery Question
no i think you just killed the battery, the recharge or jump is all you probably needed. However if you have further starting problems you might want to get that battery recharged or go for a new one.
Old 07-15-2004, 10:35 PM
b18lsvtec b18lsvtec is offline
Banned
I agree. +1
Old 07-16-2004, 03:14 AM
ZX2000 ZX2000 is offline
to recharge, start the car and let it run... the battery doesn't run the car after its started so all the extra juice that the alternator pumps out and isn't used goes to the battery to recharge....
I agree. +1
stfu postwhore....... if your not gonna help.. go drive your b18lsvtec fag...
