Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-15-2004, 06:51 PM
xmastanax xmastanax is offline
Unhappy steering shaking b/w 60-80mph
I don't know if it's wheel balancing or allignment, cause just got it alligned and balanced, infact i took the car again to the Goodyear people.
as soon as it passes 60 the steering starts shaking not much, hardly unoticible but i know its not normal.
if this has happen to anyone or if anyone got any suggestions let me know.
99 maxima bought 2 months ago.
take care
MAXIMA luva
Old 07-15-2004, 08:50 PM
95maxsewv 95maxsewv is offline
Re: steering shaking b/w 60-80mph
take care
MAXIMA luva
mine does that too. i was going to get it alligned and balanced.. let me know what you find out.
Old 07-15-2004, 09:14 PM
tdaily tdaily is offline
If your tires were balanced recently it's probably one of your front tires. It could be a wheel but it's not as likely. Try changing your wheels and tires around. Put the one's on back on the front and see if that helps. If you just had them balanced and/or rotated (in other words if the people who balanced your tires put them back on at a different location) then that could be why you're getting a shake. If the tires weren't rotated regularly before you got the car, then the wear may be off and this can give you a pull and/or a shake when they are finally rotated.
Old 07-16-2004, 07:39 PM
justin39640 justin39640 is offline
sounds like tires maybe u lost a weight or they were improperly balanced
loose steering and suspension parts would be very noticeable and at most speeds
if the vibration feels like an oscilation its most likely the tires
Old 07-18-2004, 09:12 AM
Hoochiecoochie Hoochiecoochie is offline
I experienced a similar problem and it ended up being the tires. Now let let me calrify. Check the thread wear. Even though it may not be down to the "limit", it appears that the Maxima is more sensitive to the wear. I expereinced this o the original tires as well as with Michelins. I am going to make an estimate that if you are down to approximately 15% thread remaining, replace the tires. You can try rotating the tires around also as mentioned, however, make sure that you have sufficient thread left on the other tires to make the test.
Old 07-19-2004, 05:34 AM
jsprack5 jsprack5 is offline
if its only at high speed, then they just need to be balanced.OR check to see if any tires have bubbles.
Old 07-19-2004, 06:55 PM
first of all thanks for the input.
My tires are brand new, but their no big name,something Cobra.
someone told me that it could be my transmission, that's what scared me the most. but the car runs just to good other then shaking(which is also not too much)
Goodyear did my balancing alighment and rotation. i am gonna try someone else now.
thanks all
Old 07-20-2004, 10:48 AM
i just had my car aligned and all the tires rotated and balanced.. i think it may be the wheel bearing.. it sounds just like the sound of a warped rotor on front brakes but you can't really feel it. around 80 the car also has a small but noticeable vibration. are maximas known for front bearings going out? any ideas on what else this might be.
