Old 07-15-2004, 05:58 PM
Kris_873 Kris_873 is offline
form non-to turbo
ok i know you can convert a nonturbo to a turbo, but is the twin turbo the only one? cuz i want to make my 94 sl a turbo, but i only want to make about 5-10 psi.
Old 07-15-2004, 06:43 PM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
you can do a single turbo conversion or a tt conversion. some people have simply swapped in a VR-4 engine (which I used to think was way complicated, apparently its not.) and there are kits you can buy to convert from n/a to turbo. Why do you only wanna boost 5-10psi???? are you gonna leave the n/a pistons or something?
Old 07-15-2004, 08:02 PM
Yeah actually . I plan to (once i get the green) make the 3.5 bore and get the upgraded pistions from 3sxpreformance. the reason for the 5-10 is that i don't want a gas hog, well worse than it already is anyway
Old 07-15-2004, 08:03 PM
Re: form non-to turbo
do you know where i can get one of those kits?
Old 07-15-2004, 08:18 PM
I havent done a conversion so I wont be of much help but a few people here have and they will probably advise you best. As for the kits check out www.gtpro.com
Old 07-29-2004, 10:22 PM
appriciate the info
Old 07-29-2004, 10:28 PM
StealthModifier StealthModifier is offline
Where is there a kit to convert an n/a to a turbo?.. ive only seen turbo upgrade kits
Old 07-29-2004, 11:06 PM
racer6 racer6 is offline
save up for a vr4 the conversion for your sl is not worth it you are looking at a big headache and a empty wallet. the turbo's for the car are really expensive....
chris's bad azz 3000gt sl (''sucks gas & hauls ass'')
(chick magnet)
Old 07-29-2004, 11:16 PM
racer6.. how much is a turbo for a na dohc?
Old 07-29-2004, 11:19 PM
well i was lookin at the gt pro page and i thought they workedon the na cars like musashi was saying if so then you are talking 3,000 to 5,000 dollars
(chick magnet)
Old 07-29-2004, 11:28 PM
PearlGT PearlGT is offline
aha, if you are patient you can find parts for a tt conversion cheap and it can run you as little as 1,500, i've even heard of people doing it for about a thousand but they were cut a lot of slack because maybe they picked up parts from a junkyard or a member from 3si.org for really really cheap. If you do it yourself it will be a lot cheaper, because it can be expensive to get a shop to do it.
If you can find a vr-4 engine for cheap then more power to you, they are few and far between in my experiences though as i look on ebay right now i can find one or two.
A used turbo (single) can run from 100-500 dollars im sure depending on the condition its in and power it puts out.
Old 07-29-2004, 11:37 PM
if you put a turbo kit on an na do u have to change the ecu?
Old 07-29-2004, 11:48 PM
not with an mtx as far as i know, i have heard of a few complications with an atx however
Old 07-30-2004, 12:13 AM
what exactly is mtx & atx? is that manual an automatic transmissions?
Old 07-30-2004, 12:48 AM
the item at www.gtpro.com is a supercharger, that means it's belt driven instead of by exhaust right?
