Old 07-15-2004, 05:42 PM
mr makarov mr makarov is offline
Question I have a problem, I loose horspower at high RPM
From the start it accelerates fine, but then I step on gas the RPM goes up 4000 & 5000 with no "kick" to it, there is no misfires it just not picking up like it used to. Also SES light is on. I had this for 3 days know. Does anybody know what it is ?
I have the following Mod's:
ColdAir kit, ECU chip
Camaro 97 RS, 3.8l
Old 07-15-2004, 06:15 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: I have a problem, I loose horspower at high RPM
could be a slipping trans, get the code scanned that is setting the light, and it will probly tell you the problem with the car.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-15-2004, 06:18 PM
Also I forget to mention I have bad catalytic converter, can it cause this?
Old 07-15-2004, 06:25 PM
89IROC&RS's Avatar
BINGO!!!! a bad cat will act like a cork in the exhaust system, and will create more backpressure the higher the engine speed, and choke the engine, so you wont have any power.
Old 07-15-2004, 06:33 PM
Couple months ago then catalytic went bad, I talked to couple mechanics they gave me some crazy prices, one wanted $900 and another wanted $1200 to put a new one. But one of them told me that without a catalytic the car will run better, it just won't pass the inspection. So I guess he lied right?
Old 07-15-2004, 06:43 PM
89IROC&RS's Avatar
no no, he didnt lie, he was talking about cutting the cat out completely, and just running strait pipe, a failing cat is a really bad obstruction.
as far as the prices, that does sound a bit high, the cats are expencive though, like 3-400 bucks, and hourly rates to install are usually the killer. but im sure you could find it cheaper.
Old 07-15-2004, 06:46 PM
Alright now I know what to do, thank you for your help.
Old 07-15-2004, 06:47 PM
89IROC&RS's Avatar
no prob man
Old 07-15-2004, 08:47 PM
Lightbulb Re: I have a problem, I loose horspower at high RPM
I've been searching for catalytics on the web, and I found this cleaner, sounds like BS. What do you think
CATALYTIC CONVERTER CLEANER/DEODORIZER
Breaks up clogs to help restore fuel efficiency and horsepower prolongs life of converter and helps prevent "rotten egg" smell Cleans while you driveпїЅsafely and easily For all catalytic converters Simply pour into carburetor or gas tank. Immediately begins to clean combustion chamber oxygen sensor and EGR valve. Use of this cleaner/deodorizer may help you pass emissions control test. Package contains two 16-oz. cans.
$9.95
Old 07-16-2004, 01:13 AM
blueturtle blueturtle is offline
Send a message via AIM to blueturtle
well heres my 2 cents i say just rip off the cat urself get a nice piece of pipe and 2 clamps and clamp it on bingo gain like 2 ponies and no more shitty cat and when its time for emitions just put it back on with the clamps
Old 07-16-2004, 01:29 AM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
I agree!
Old 07-16-2004, 09:15 AM
Re: Re: I have a problem, I loose horspower at high RPM
The problem is that it comes in one piece, and since I don't have a welding machine it's not going to work out.
Old 07-16-2004, 12:52 PM
sykotic1 sykotic1 is offline
1200 bucks for...one cat? two? do you guys realize you can get cheapie hi flows for like $50 a piece? i mean unless the baffling is messed up what the hell is the difference?
Old 07-16-2004, 12:56 PM
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW just to illustrate my point, if its a factory replacement you shouldnt need anything else right?
Old 07-16-2004, 01:03 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
thats not a high flow cat...
