Old 07-15-2004, 04:32 PM
Juggalo Juggalo is offline
no spark! Help please!!
so i just put a new used engine in my 99 gs.. and it has no spark! i changed the coil pack over and the sensors from the old motor and nothing? what else can i try? can anyone please help me!! thanks
Old 07-15-2004, 05:16 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: no spark! Help please!!
Have you checked the fuses?
For Sale 98 Eclipse GS, 5 spd
Old 07-15-2004, 05:31 PM
what fuses should i check?
Old 07-15-2004, 05:38 PM
ashah000's Avatar
I am not sure if there is a fuse for it but look at the fuse box and see if something looks blown.
Also maybe the wire harness that runs to the coil could be the problem
Old 07-15-2004, 08:15 PM
any more ideas guys.. no fuses are blown and i took all the censors off the old motor which still ran.. and nothing .. just turns over and over.. ?
am i missing something ? i know someone out there has an answer!!!!
Old 07-15-2004, 08:22 PM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
have you checked and recheck the plugs? what about the ignition.
edit* Sparkplugs""
06 Charger SRT-8 black.
Old 07-15-2004, 08:44 PM
91GST? 91GST? is offline
if its not the same engine model you might need an ECM for that engine. if thats not the problem, just plug up an OBD-II reader and let the ECM tell you
Old 07-15-2004, 09:09 PM
it is the 420a .. same as what was took out.. where do i pick up a OBD-II ? i rechecked all the connections and everything is right.. let em know where to get that obd thing.. thanks for the tips! hopefully i can figure it out soon i have been without my dsm for almost 3 months and its killling me!!!
Old 07-16-2004, 04:52 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
crank sensor? that controls the spark right there!!! CHECK IT! its on the back side of the block, somewhat in the middle... you can get to it from under the car, if there is just a hole then you need to put a crank sensor in it! if its there check to see how tight the connection is and if there is a good connection take the sensor out (2 - 10mm screws holding it in) and either have it tested or get a new one!
Old 07-16-2004, 07:33 AM
LittleGSEclipse LittleGSEclipse is offline
Send a message via AIM to LittleGSEclipse
Juggalo If I were you I would definately check all the wires make sure everything is plugged in. I did the same swap a few months ago. It was a pain in the ass. Also I dont know if you notived but check the crank sensor. And there is also a little resistor on the engine somewhere it might be on the top of the engine to the right or on the front of the engine to the right and it has a single wire going to it I had mine unplugged once and it made my car act funny..... the last option might be to check the coil pack make sure you have the right one. Because there are to coil packs depending on which engine you got. One has flat terminals and the other has round terminals. So once again make sure your wiring is meeting up properly and everything is plugged in nicely......... Hope that helps let us know the outcome.
Old 07-16-2004, 10:49 PM
well i checked and checked everything once again .. changed the crank sensor from the old motor because i knew it still ran.. and nothing yet? im getting 5 volts to the coil pack but after that im getting nothing? im getting pretty pissed off because my dsm has been down for about 3 months and there would be nothing better than gettin my car back on the road.. so if anyone has any more ideas or if im missing anything stupid please let me know.. i have chaned all the wiring and sensors from the old motor because i know that it ran and it just turns over and over but no spark!!! please let me know if you know anything im missing!
i can't use an obd tester because they only work if your check engine light comes on right? i think im just gonna blow the damn thing up! lol
