Old 07-15-2004, 04:15 PM
97TaurusGuy's Avatar
97TaurusGuy 97TaurusGuy is offline
Send a message via AIM to 97TaurusGuy
Camshaft sensor problem
I was replacing my camshaft position sensor wen i discovered that the metal piece in the center of the sensor as well as plastic that holds that metal in place has melted onto the shaft in the housing that the sensor sits on. Has this happened to anybody else?? Anybody have suggestions on what to do?? Thanks for your help!!!
Old 07-21-2004, 11:33 AM
2000SEFFV 2000SEFFV is offline
Re: Camshaft sensor problem
I don't have an answer - only more questions. I have a 2000 SE and had the CPS replaced at about 40,000 miles. It was making a "chirping" sound. Now with over 70,000 miles, that sound is back. My questions: Where is the sensor on the engine? How did you know yours needed to be replaced? Do I need any specialized tools?
Old 07-21-2004, 10:36 PM
mynustheckat mynustheckat is offline
Same here with the melted sensor. A few of the pieces came out easy but there is a chunk of it welded on the camshaft. I don't know if I should just get a chisel and clean out the old stuff so I can put the new sensor on and get the engine light off. I need a sticker.
Old 07-30-2004, 11:11 AM
TomV TomV is offline
The Haynes manual, available at your typical auto parts store, shows the assembly is located on top of the engine, underneath the spark plug wires 1,2 and 3, that are routed to the rear of the engine. You need to take off a few parts, such as an air hose, some electrical connectors, throttle cable assembly, plug wire routing harness and such. It is not too time consuming once you see the book and the sensor's location. You need the proper size wrenches. There is a flat, rectangular, plastic wire harness directly over the sensor that does not come off. I bent it around a bit and it cracked some, but not enough to cause any real damage. It does allow the overhead access needed to remove the plastic sensor from its housing. You need some small socket wrenches for this. I just bought a set of small sockets, metric and English, for stuff like this. An extension shaft of at least 6 inches is very useful here.
Once the sensor is removed (2 screws and electrical connector) you can view the rotating shaft in the synchronizer housing to determine the condition of the semicircle vane that rotates through the magnetic field of the sensor. Check the sensor for damage too. The magnet in the center of mine was snapped off and caused the vane to be bent inwards. If you do not see any damage to the metal within the housing then just replace the plastic sensor and see if that solves your engine light problem. Blow out any loose parts before assembly. If there is noticable damage to the metal within the housing then you need a new synchronizer. I paid about 30-35 for the plastic sensor and $159 for the metal synchronizer assembly. But I paid no labor. The job takes about an hour if only the plastic sensor is bad and about 2 hours if the synchronizer is faulty and you use the following procedure to properly align the system. It may also give you an excuse to buy some small socket and box wrenches as well! If replacing only the sensor does not eliminate the engine light then you could have a faulty synchronizer (gear not meshing properly) or an electrical problem between the sensor and the computer.
The tool used synchronize the system in the fashion described in the Haynes and Ford documentation (I have a copy of each) assumes that the #1 cylinder is at TDC. It aligns the vane of the rotating shaft relative to the magnetic circuit of the CMP Sensor. The vane disrupts the magnetic field as it rotates and the signal is sent to the computer. The 38 degree setting of the housing is not necessary for the synchronizing aspect but for assuring the electrical connector can be placed on the sensor since it is a fairly short cable.
The rotating shaft can fit in any one of 14 positions (14 teeth on the gear). It does not fit only one way, and is not polarized as has been stated in previous messages. The Ford and Haynes manuals do not indicate this feature. I was also able to place the assembly in more than two different positions myself. Therefore, if you want to replace this assembly without the use of the tool and the setting of the #1 cylinder to TDC as described by Ford, you must record the position of the shaft's vane prior to its removal, relative to the housing. This is similar to using the synchronizing tool, but with the postion of the cylinders in an intermediate state.
After taking the plastic CMP sensor off, I transferred the position of the vane onto the top surface of the housing rim with a Sharpie fine tipped pen. The vane was bent out of shape from the magnet that fell from the sensor, but the edges were still in place. I then transferred a mark to the manifold across from one of the three small gaps in the housing rim, the one opposite the large gap for the electrical connector. This would ensure that housing is placed back to its original position and there would be no problem getting the electrical connector back on.
The entire assembly is removed with the removal of the single screw on the engine block. The shaft rotates CCW on removal.
Transfer the marks on the old assembly onto the replacement assembly. Oil the shaft thoroughly. Place the unit into the engine, inserting the shaft onto a pin in the engine. The vane should be rotated CW as it is pushed down. Once the assembly is against the engine, check the alignment marks for the vane/housing and housing/manifold. If necessary, pull up the unit and reinsert it in another position until the alignment marks correct. Now you can replace the hold-down screw and its fork/washer to keep the housing in place.
