Horn Went Low
My horn went bad a couple weeks ago. I dont know if it's the fuse because the horn still works, it just sounds like a Civic's horn now and not one belonging to a truck.It's quite embarassing actually.Has anyone had the same problem. Help.I need my horn back.
97 GC |
Re: Horn Went Low
If the horn still makes a "noise" the fuse is ok.
Unless the coil in the horn is bad, it is either a bad ground at the bolt holding the horn to the body, the horn relay, the switch or a bad harness connector. Try loosening and retightening the mounting bolt first. |
Re: Horn Went Low
My horn sounds a bit "small" for the size of my vehicle as well, only got it 3 weeks ago, tried out the horn (expecting something good) and was rewarded with a "peep"
Re: Horn Went Low
i jusr replace mine for an air horn ( $ 27 @ pepboys) not what i hope for but not a honda beep any more.
