Old 07-15-2004, 01:34 PM
sdm1964 sdm1964 is offline
Guages
The guages in my daughters car do not work except now and again, Most of the time not. They jump and then go nuts and quit working. Everything else on the guage panel works except the guages. Is there anything I can check? The fuse for the guages is good.
Old 07-15-2004, 01:38 PM
Tech_n's Avatar
Tech_n Tech_n is offline
Re: Guages
What guages are you talking about
Old 07-16-2004, 06:16 AM
Re: Guages
The speedometer, tach, Fuel guage and temp guage. The warning lights still work. The odometer still works even when the speedometer reads nothing. What ever is wrong only effects the guages.
Old 07-17-2004, 07:01 PM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Re: Guages
Could be a loose inline connection on the relay , its a power wire from the battery to the relay its red cant miss it , should be bolted on tight or it vibrates. If it has loose conections it gets power then looses it then gets it again. Its just a posability to help narrow down the problem.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
