Old 07-15-2004, 01:29 PM
mitch311 mitch311 is offline
Does Integra Seats Bolts right up to the Civic Chassis?
Hi,
I was wondering if Integra seats bolts right up to a Civic Chassis, particularly the 92' Hatchback. Is it as easy as removing the four mounting bolts and then popping in the Integra seats, and bolt it in?
Thanks in advance.
Old 07-15-2004, 01:43 PM
EatTheBlue1's Avatar
EatTheBlue1 EatTheBlue1 is offline
Re: Does Integra Seats Bolts right up to the Civic Chassis?
dont know but why u all are at it . how bout RSX seats in a 99 civ
[email protected]
Old 07-15-2004, 02:04 PM
Beastiek2's Avatar
Beastiek2 Beastiek2 is offline
Banned
Send a message via AIM to Beastiek2 Send a message via MSN to Beastiek2
RSX bolt in 7th gens
Old 07-15-2004, 03:31 PM
Re: Re: Does Integra Seats Bolts right up to the Civic Chassis?
I chose integra seats because it would be cheaper and there's a whole bunch out there. As for what years integra, it doesn't really matter. Just as long as it's 1990+.
Do you guys know whether those year integra seats will just bolt right up to a 92' civic hatchback?
Thanks.
Old 07-15-2004, 10:20 PM
jameskersten jameskersten is offline
94+ teg bolts into 92+civic. 90-93 teg will bolt in with some mods to the rails.
1993 honda civic si -turbo charged b18c1
dynoed: 316whp at 11lbs
Old 12-27-2004, 09:38 PM
coke162 coke162 is offline
Do the teggy seats bolt in all 5th gen styles llike sedan and coupe?
Old 12-27-2004, 09:40 PM
And also will the backseats seats fit in a coupe
Old 12-28-2004, 10:04 PM
bingisSD's Avatar
bingisSD bingisSD is offline
Send a message via AIM to bingisSD
okay when i bought my 92 civic hatch it had integra seats and only two of the bbolts match, not all four, it is a pretty ugly fit you have to do some drilling. the rear seats im not sure aout but they sure look the same. i straight up threw my teg seats out because the fit was really loose. it is not a direct bolt on and you will have to bend the rails and stuff. just get some cheap bucket seats
www.cardomain.com/id/bingissd
http://www.automotiveforums.com/vbulletin/showthread.php?p=2660831#post2660831 <MEET IN DAYGO
Old 12-29-2004, 08:34 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
You can use your current seat rails and just drill new holes in the 'Teg seats for them. That way they'll bolt right up and the seats will sit at the correct height for your car.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 12-30-2004, 02:28 AM
bingisSD's Avatar
did you do that yourself? any tips?
Old 12-30-2004, 12:04 PM
I haven't done it personally, but I know probably at least half a dozen people on the Team Sol forum who have. The problem with Del Sol's are that the seats sit very low and using the original rails that come on seats from other cars sit higher, so you're driving around with your head smashed against the roof.
They typically just drill new holes for the Del Sol seat rails and bolt the rails to the seats (some even weld the Sol rails to the seats) and then the new seats fit exactly the same since the original rails are being used. And this allows correct seat height.
I would imagine this works on the other Honda's as well. Feel free to pop over to the Team Sol forum in my signature and check it out. We have plenty of ex-Sol'ers there so don't feel you have to have one to post there. There's also a Civic forum too if you want to head over. There are a lot of knowledgeable people there.
